Author Topic: Window washers  (Read 780 times)
Offline Haribo!
Window washers
« on: 07 March 2009, 15:07 »
Got a problem with me window washers, bought the car a month ago and it had the rear washer tube blocked off and re-routed to the front, I asked the garage why and they said it was because it needed a new washer stalk to make it work, So I replaced it and put all the tubes where they should be and the problem persists.
I currently have the rear working fine but the front doesnt even try, if its not the stalk then what could it be? The moter?
sharpie
Re: Window washers
« Reply #1 on: 07 March 2009, 16:39 »
new motor, sounds like it's only working in one direction
Offline Ben Lessani
Re: Window washers
« Reply #2 on: 07 March 2009, 23:25 »
The way the motor pumps front/back is just by reversing the polarity on the motor. Just put a couple of bridge wires between the batt +ve and -ve to the two terminals on the motor, then try it the other way.
Do a search, this question comes up a lot ;)
Offline Haribo!
Re: Window washers
« Reply #3 on: 08 March 2009, 03:02 »
ah thanks guys, il try that then.
(I did a search and found bugger all ;) )
