Author Topic: Need less roll and better handling!  (Read 3040 times)
Re: Need less roll and better handling!
« Reply #20 on: 08 March 2009, 00:26 »
Coilovers, the ride will harsher but the handling will be loads better.
not sure i agree; surely just because the ride is harsher dosnt mean the handling will be better? The jamex are firm and low without being too harsh and £35 ish cheaper- Probably a better choice for someone wanting less body roll for little £££'s
Trust me the handling was loads better, the standard set up on the mk3 is crap.
Offline bobbito
  • Hammer and Chisel Engineering
« Reply #21 on: 08 March 2009, 00:45 »
/\/\ x2
Offline ian24driver
« Reply #22 on: 08 March 2009, 08:18 »
i had the same prob with my mk3. bought some coilovers from hottuning for £160 delivered and there mint, not rock hard at all and they make it look so much better, good quality too
Offline Paul86S2
« Reply #23 on: 08 March 2009, 19:54 »
If you are after improving your suspension the best idea is to find out what is wrong with what you have got first.
If you are in Bristol go to somewhere like Protyre and get them to do a free suspension check and tell you what is wrong.
Then decide where you need to spend the money.
A good home check for shock absorbers is to push down on the corner of your car (x4) and release, the corner should pop up and bounce once, if it bounces two or three times your shock absober will need replacing.
Changing anti roll bars will not cure problems with defective springs, shocks, or rubbers. Same goes for changing any of the other parts, if you change the wrong part it will not fix problems with other parts. Anything you change in the suspension will have an effect on the other parts of the suspension.
If you are after improving the suspension for the cheapest price, get it all checked and replace anything that needs replacing with standard parts.  If you can afford more money first get it checked to see if anything needs replacing then go for the best suspension you can afford either coilovers or struts and springs. Remember the lower you go the harsher it will probably be.
Paul
Offline seismic22
« Reply #24 on: 08 March 2009, 21:08 »
Thanks everyone! just the info and opinions i was looking for! Paul, i think your advice is spot on and good common sense and info i will bare in mind! Cheers!
MK3 GTI 16V. The fun starts at 3.5k.
