Golf mk2
rev counter & clock stopped
Topic: rev counter & clock stopped (Read 4858 times)
KelvinIOW
Re:rev counter & clock stopped
Reply #10 on:
19 July 2004, 09:22 »
oh yer i thought i was going mad then i thought i did a reply somwhere out there hey still sane juuuuuuuuuust
lewis
GTI forum regular
Reply #11 on:
19 July 2004, 13:22 »
I had the same problem with my MFA and rev counter. The rev counter would blip up to about 1000 RPM and the water led would flash. I tried removing the correct fuse a few months back but this had no effect. I then took the clocks out to check the connections but everything seemed fine. In the end I bought a new set of clocks which fixed the rev counter but not the MFA. Does anyone know what could be causing the MFA not to work as it was defiantly working in the car I tuck the clocks from.
KelvinIOW
Reply #12 on:
19 July 2004, 16:24 »
Lewis have u tried disconnecting ur battery for about 30 seconds then reconecting it cos it worked for me if u havnt tried it then give it a go tell me how u got on!
(Knowledge was acuired by Blue Mk2 many thanx)
daros
GTI forum regular
Reply #13 on:
19 July 2004, 19:11 »
The disconnecting battery thing hasn't worked for mine...neither for that matter has removing/changing the fuse in the fusebox. FRUSTRATING!! lol
Haydn
Reply #14 on:
19 July 2004, 21:20 »
My rev counter and MFA has never worked. I was told that it is a common problem. there is an advert in the Rabbit magazine and apperently they are charging 100 to fix the problem!!!
Do u think i should try disconnecting my battery?
JETTA GTI. Lots of fun with room for the shopping...
gibson
GTI forum regular
Reply #15 on:
19 July 2004, 22:50 »
this happened to me w week or so ago. I disconnected the battery and it worked, but now my digital clock doesnt keep the correct time. Any Ideas people??. it seems to only work when the engine/ignition is on
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Reply #16 on:
20 July 2004, 08:49 »
Quote from: gibson on 19 July 2004, 22:50
Sounds to me like there is no constant feed to the clock.
Does position 2 of your MFA keep all the details ? If this resets itself then I'd deffo say it doesn't have a constant feed.
Last Edit: 20 July 2004, 10:36 by gibby
......now officially dubless.
piggy
Here all the time
What you lookin' at sonny?
Reply #17 on:
20 July 2004, 17:19 »
Just disconnected the battery thinking," this sounds to good to be true". And I was right.
The revcounter and MFA still don't work, though the clock reset, WOW.
Anyone with anyideas before I start to have to shell out some serious dosh :'(
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #18 on:
21 July 2004, 10:55 »
Buy a second hand set of clocks, alot cheaper than spending ?100!!
piggy
Here all the time
Reply #19 on:
21 July 2004, 23:36 »
While out tonight the Revcounter started to work and the MFA was also fully functioning with the water temp light not flickering. I thought that for a short while God had seen fit to bless me with some good luck.
Should have known that after just 1 mile it went intermittent again.
Any more ideas, sounds like a faulty wire/connection somewhere?
Golf mk2
