Author Topic: Torque or power?!  (Read 2864 times)
VeeDubGTI16v
Re: Torque or power?!
« Reply #10 on: 02 March 2009, 20:21 »
re manifolds i have read 4-2-1 favours torque and 4-1 favours power, how much difference it actually makes i have no idea
Offline danny_p
« Reply #11 on: 03 March 2009, 10:12 »
current thinking favors 4-2-1.   if desinged right  gives inprovements of uc wide part of the powerband,  starts sooner and goes as high in the revs
all the VW's have gone bar 1.
Offline wopdat
« Reply #12 on: 03 March 2009, 11:51 »
I'm sure the volume of the boxes and the baffles will make a difference... my cars sounds great but i need more torque!!!
i just can't pull away quick enough but i sure an catch them!!! But like i said the torque is definately missed so what would be the best system to use in conjunction with my miltek?!
Offline danny_p
« Reply #13 on: 03 March 2009, 12:06 »
there is no definitive answer,  they onlt really way to tell  is to dig out an enigne dyno and strap a test engie to it and see what effect diffrent systems have,    i have the use of an engine dyno and can get hold of a 16v motor quite easy  but somewhat lacking in exhaust systems
Offline Tara
« Reply #14 on: 03 March 2009, 16:50 »
Torque wins races BHP sells cars  :smiley:
Torque gets you off the line, BHP gets you over it :wink:
Torque gets you off the line and skill gets you over it  :smiley:
White GTI PP......
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #15 on: 03 March 2009, 18:07 »
Torque is cheap, but power corrupts :grin:
No seriously.  I had a mk4 2.0 gt tdi, which was awseome to drive because of the Torque. All the fun in driving is the acceleration, the short sharp squirts of power between corners...all of which increases with torque - pulling power.
Offline danny_p
« Reply #16 on: 03 March 2009, 18:15 »
really it's nether, it's the area under the graph that counts if you want a fast car.   loads of torqe but no revs is pants  but loads of revs and no torqe is pants, loads or torqe  for loads of revs = :>  by default it has shed loads of power
VeeDubGTI16v
« Reply #17 on: 03 March 2009, 18:37 »
because its great fun changing gear at 4k isnt it  :grin:  :rolleyes:
Offline Neo Badness
  • Feet are for pedals
« Reply #18 on: 03 March 2009, 21:28 »
Torque for 0-60mph (Overcoming inertia)
Power 60mph+ (Overcoming aero resistance/drag)
Have a Magnex on my mk2 valver at the mo witha 4 into 1 mani which is ok. Not too noisey.
Went from a mk2 8v, to mk3 16v, to mk2 16v, felt a bit gutless to compared to mk3 hence my upcoming engine swap for ABF... :grin:
Offline wopdat
Exhaust systems... Torque or power?!
« Reply #19 on: 04 March 2009, 13:32 »
I have another powerflow box which is much smaller than the sebring i'm using so i'm gonna try that and see if it makes a difference. I also feel losing the front box & manifold box has severly affected the torque so gonna swap n change to see wot happens.
Will the exhaust setup affect the timing? I mite check that tonigt, a quick job. :undecided:
Also danny, where you based? I could be tempted to visit you and conduct a comparison experiment using the different boxes!! :huh:
