Author Topic: 60 or 40 mm??  (Read 11932 times)
Offline JC
  • Back in the North.
Re: 60 or 40 mm??
« Reply #50 on: 17 March 2009, 20:21 »
deffo do ya top mounts, :afro:  i know these things to my cost  :cry:
Offline OakeyDoak16v
Re: 60 or 40 mm??
« Reply #51 on: 17 March 2009, 20:39 »
I cant believe i managed to stay on the road this long without ending up in a tree or worse :sad:
Can't wait for next day off now to go for a blast :wink:
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
Re: 60 or 40 mm??
« Reply #52 on: 18 March 2009, 00:51 »
Just for reference really..
My car runs the GT kit, remember Weitec is the smaller brother to KW so no compramise in quality & good value for your money, after trying many different set-ups this kit worked well for what I was looking for in the handling characteristics, it's also height adjustable on the rear and it's a shorter damper/rod to match the shorter springs.
Mine is the 40/40 kit, with front Bonrath top mounts, Eibach ARB's with 16v drop links, standard rear axle & front w/b bushes.
Front ride hieght set to 40/41mm, camber 1 degree negative & rear ride set to 37mm
Nose down stance has the following values
1.) Car looks right to the eye
2.) Better stability under braking
3.) Under full throttle the nose remains planted and the rear compression is down to a minimum under load
Re: 60 or 40 mm??
« Reply #53 on: 18 March 2009, 09:53 »
Nice Summary :cool:
Offline paultownsend
Re: 60 or 40 mm??
« Reply #54 on: 19 March 2009, 17:17 »
jesus the price of weitec stuff has gone up!  i got mine from c&r for £280 with a set of g60 perdator pads! i was going to go for the coilovers but these were a steal :)
good kit though, better than the eibach springs thats for sure!
Re: 60 or 40 mm??
« Reply #55 on: 19 March 2009, 17:24 »
I'm really impressed with the set up now after running with it for a couple of days. It's a good firm ride and very smooth. The car feels like it's handling exactly how it should. Would deffinately recommend. :smiley:
Offline MarkS
Re: 60 or 40 mm??
« Reply #56 on: 19 March 2009, 21:38 »
Brilliant result mate  :cool:
Re: 60 or 40 mm??
« Reply #57 on: 19 March 2009, 21:50 »
Cheers mate, well happy! :cool:
Offline twistedblack69
  • Proud mk2 user and abuser
Re: 60 or 40 mm??
« Reply #58 on: 20 March 2009, 15:37 »
Can someone give me a quick rundown of what each thing is and does in the suspension?? I'm confused by the terms ARB, dampers and top mounts  :lipsrsealed: :lipsrsealed:
Re: 60 or 40 mm??
« Reply #59 on: 20 March 2009, 21:39 »
ARB's are anti roll bars.
Top mounts are fitted onto the damper before mounting onto the car
Dampers are aka shock absorbers
Springs are the springs that go round the dampers
And dont forget bushes and bump stops. :smiley:
