Author Topic: 60 or 40 mm??  (Read 11939 times)
Offline OakeyDoak16v
Re: 60 or 40 mm??
« Reply #10 on: 26 February 2009, 00:17 »
As you say Mark it's within the budget i've got to play with. I know you very much get what you pay for with this kind of thing so will give them a go.
Cheers mate. :smiley:
Offline Ben Lessani
Re: 60 or 40 mm??
« Reply #11 on: 26 February 2009, 00:28 »
I personally have Koni dampers and Eibach springs
Rate them very highly!
Adjustable damping too which is cool :)
They're not cheap and only lower 30mm but are regarded as a very good set up.
Another very highly rated spring would be the H&R spring which lowers 40mm that I would have gone for had I not chosen Eibachs.
Depends how much money you have to play with really :)
What kind of money did you spend on the setup?
Offline MarkS
Re: 60 or 40 mm??
« Reply #12 on: 26 February 2009, 00:34 »
Too much really
I got to the stage where it was basically-
- Cheaper and nearly my ideal set up
- Ideal set up (the one I really wanted)
- Spending yet more on some coilovers from Koni/Eibach etc.
I really couldn't stretch to the coilovers and knew I would be disappointed with the 'nearly ideal' set up
So basically scraped all my funds together and went for-
Eibach springs
Koni yellow dampers front and rear
Genuine g60 top mounts
About £550
I winced a lot when I clicked the order button
Worth it though :)
Offline Ben Lessani
Re: 60 or 40 mm??
« Reply #13 on: 26 February 2009, 00:36 »
Eeek, quality costs!
I need to bump a ride off someone with a good setup to really see what its like.
Re: 60 or 40 mm??
« Reply #14 on: 26 February 2009, 00:37 »
As said all the time you get what you pay for but sadley thats too much for me atm. Bet it goes round corners like its on rails tho. :smiley:
Offline MarkS
Re: 60 or 40 mm??
« Reply #15 on: 26 February 2009, 00:41 »
If you're at Shady P's meet in easter I'll happily demonstrate :)
I need to play around with the damping really, I have the front set very hard; the rear needs to be cranked up half a turn.
That's the only disadvantage really- you have to remove the rear struts to adjust their damping :(
Re: 60 or 40 mm??
« Reply #16 on: 26 February 2009, 00:45 »
Too much fettling for me that is. I would never be happy and prob get ocd on it. I need a simple set up and then work on other aspects such as anti roll bar upgrade if required.
Offline MarkS
Re: 60 or 40 mm??
« Reply #17 on: 26 February 2009, 00:45 »
It does mate  :cool:
I reckon I'd scare myself long before the car gave way!
It's worth complimenting the new set up with decent tyres too
ARBs and bushes are definately a good shout as well
Unfortunately funds ran out long before I could get either of these :(
My front arb looks absolutely shot too
Offline MarkS
Re: 60 or 40 mm??
« Reply #18 on: 26 February 2009, 00:47 »
Ahhh I'm the opposite! I love to be able adjust things  :laugh:
Definately can see the advantage of having a simple, from factory, optimum set up though :afro:
Re: 60 or 40 mm??
« Reply #19 on: 26 February 2009, 00:52 »
Tyres, whole new can of worms right there. (Eagle F1's FTW)
ARB's dont know too much about tbh but having done the poly bush upgrade i'm testing out one thing at a time and working on it that way.
