Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240437 times)
Offline adaptorman
well seen as the sun was shining this after thought id do itbit more cut and chop  and yes more bloody welding lmao
finished the brak pipes and fittings and the bit of welding i missed
the exhaust was rubbing so ,the only way was make some room
 and needed a few patchers on the rear pannel too ,evern thow i was tempted to chop the lot out and make a bit more room
and had time to still a patch on the rear bed ,as i was going to rip the lot out ,,but ,that more months of messing ,so ,,,that can be for another day ,,
and wraped a bit of mesh around the pipe
Offline dubsport
  • TDI POWAR!
this thread it just straight out insane haha i love it .... id have no idea where to start!
Offline OakeyDoak16v
You will never know. This is balls out modding worry about it later material :cool:
Offline adaptorman
all fun ,,,, :grin:bit more here lol
a few bit done and made today first thought id better finish the brake pipes off and bleed them up ,,
nice nipple and was the last one too,that those bleed up and we have brakes ,,first time
then realised i forgot to make a vacum system for the servo ,, so thought ill make one in the short runnner
i was going to weld a lump of tube but thought ,erm ill had a nice tight ribbed rubber and use the correct bore and fitting
next thing cut some lumps of servo pipe and warmed them up to fit nicely and shape the bends the fit around the engine
couple of shots of the pipe around the engine
then just a few patchers welded to the bed  as its not straight
 next ill make a handbrake  ,just the finish the brakes off altogther ,but i do have a problem ,,, that is ,i carnt put a intercooler and radiator behind the pannel as there only room for the radiator grr ,evern tryed a side to idea but ,it wouldnt cool right ,,so looks like ill just have to stick the buggar on the front ,,,something i didnt wont to do ,, :banghead
Offline Organisys
  • Old and Slow...
Any room under the hood for a charge cooler?
Offline adaptorman
thought of that but i really need a big voloumr of sir with short pipes to keep air temps down ,,
just got  my mic working  as it did a smoke test today check this out ,,:eek:
http://tinypic.com/player.php?v=2ce5grt&s=5
Offline iMation
  • G SiXtY
love this build
Where did you get your manifold steel/bends from.
Meh....
Offline adaptorman
love this build
guy up the roads sells them (there arnt cheep ,but worked out a lot cheeper thern 650.00 plus delivery for a manifold for for one of these engines ,,,same applys for the homemade short runner ,,, they wanted betwen 450/550 ekk ,,thought ill make one ,lol ,,nice engines but exspensive on parts when things go wrong :rolleyes:
Offline iMation
  • G SiXtY
yeah im fabbing up my own manifold at the mo. alot cheaper :D
Meh....
Offline adaptorman
best way ,i do have another i made somewere for a 4motion lump lol
which directly bolted to the std exhaust manifolds
had this after free so ,decided to try get a rad ,its not the type i was after i think i may have re modify to a bigger one ,bit this may do ,for a trail spin
not over happy but if it will work till i can sort a custom size radiator out ,,ill be happy
think im getting there and verything looking extra tight in there lol
