Author Topic: re mapping near me?  (Read 5031 times)
Offline Ben
Re: re mapping near me?
« Reply #10 on: 25 February 2009, 12:57 »
depending on the day my car would be either at mine or my girlfriends my postcode is TS24 9NQ and my girlfriends is TS1 4RL
hi again
160 miles from my adress,no worries just pmd the other guy thats in your area with the mk5 golf,if you were both to go ahead with the remap we could offer you both a good saving as you could split the fuel costs beetween you.
                   Basic remap =195 to 200 bhp
                    R-Tech spec 1 remap=210bhp+ uprated recirc valve.and air filter good option
                    R-Tech spec 2 remap=225+bhp sports or de-cat & exhaust system + better air flow, charge cooling & recirc valve needed.
                all these 3 will be a nice constant power throughout the whole rev range,with no low down boost spikes.
« Last Edit: 25 February 2009, 18:23 by R-Tech-Ben »
the dwarf from the north
Offline JDM82
« Reply #11 on: 25 February 2009, 18:33 »
do you supply and fit the forge 007 and induction kit?
GOLF GTi - The legendary hot hatch
Offline JDM82
« Reply #12 on: 25 February 2009, 18:49 »
I keep reading about once re-mapped you may need to re new the coil pack? Not sure what a coil pack is but are they expensive? Would it be easier just to fit new coil at same time as re-map?
Offline Ben
« Reply #13 on: 25 February 2009, 20:24 »
hello mate
we can supply and fit the forge 007p recirc valve for £70.as far as coilpacks are concerned these tend to fail even in standard form.and if on there wayout a remap will finish them off.these can be had for around £30 each from the dealer (4 needed).
     we have also found that a good panel filter in your standard airbox works well.
                        regards r-tech ben
« Last Edit: 25 February 2009, 20:26 by R-Tech-Ben »
Offline JDM82
« Reply #14 on: 25 February 2009, 21:44 »
Im pretty sure my air filter is an K and N so probably just need a stage one remap and 007
Offline T_J_G
« Reply #15 on: 25 February 2009, 23:11 »
Watch out, K+N panels are oil based and can play havoc with your MAF!
