Author Topic: mk2 gti service intervals  (Read 2418 times)
Offline th3_f15t
Re: mk2 gti service intervals
« Reply #10 on: 27 February 2009, 10:07 »
From what I know, it's something like this;
Every 12 months
-Check anti-freeze mix
-Renew engine oil and filter (recommend twice a year)
-Check exhaust system
-Check idle speed and mixture
-Check clutch operation
-Check automatic transmission fluid level
-Check CV joints and boots
-Check fuel and brake lines, hoses and unions
-Check brake pads and rear shoe linings
-Check headlight beam alignment
-Check steering gear
-Check suspension
-Lubricate hinges and catches
-Check vehicle underbody
Every 2 years
-Renew brake fluid
Every 10,000 miles (15,000 km) if covering more than 10,000 miles per year
-Check brake pad linings
Every 20,000 miles (30,000 km)
-Check alternator, power steering pump and air conditioner compressor drivebelt(s) adjustment and condition
-Renew spark plugs
-Renew air cleaner element
-Renew fuel filter
-Clean and lubricate sunroof guide rails
-Renew automatic transmissioon and final drive fluid
Every 40,000 miles (60,000 km)
-Renew timing blet
Moving over to Flickr, sorry for the broken picture links!
Offline Organisys
  • Old and Slow...
« Reply #11 on: 27 February 2009, 13:46 »
They are old cars worth next to nothing. It's far simpler to drive it until something makes a noise, gets annoying or breaks completely, then fix it. Oh, check the obvious fluids etc, and change the oil when you can.
Offline Gene Hunt.
« Reply #12 on: 27 February 2009, 15:12 »
Every 12 months
-Check suspension
Every 2 years
-Renew brake fluid
-Renew spark plugs
-Renew fuel filter
-Renew timing blet
..............thanks mate,you'r a star.
Candy White ED35.
Offline th3_f15t
« Reply #13 on: 27 February 2009, 16:20 »
I would like to say that at no point did I copy this information from anywhere... :wink:
When it comes to parts, I agree with the above, just wait till it drops off/blows up/stops working. Only do work if you have to, the more you tinker and mess with things the more it goes wrong.
