Author Topic: Brake pedal travel  (Read 1053 times)
Offline tnewson
Brake pedal travel
« on: 22 February 2009, 18:44 »
Hi there,
My brake pedal has suddenly developed alot of travel...
I checked my fliud resevoir and there is no fluid whatsoever! I havent totally lost brakes but they arnt exactly good. I dont think there is a split in the system as i dont have a dual braking system so i would have lost brakes altogether if that was so.
What do i do?
tom
Offline theclash
Re: Brake pedal travel
« Reply #1 on: 22 February 2009, 18:55 »
top up fluid bleed brakes check for leaks.
 check your shoes/pads
Offline tnewson
« Reply #2 on: 22 February 2009, 18:57 »
sh!t...
Thats gonna take ages! I gotta drive this death trap to college tomorrow :S
cheers mate,
Ill learn how to bleed brakes in the dark :S
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 22 February 2009, 19:05 »
No fluid thats not good!!. you have a leak somewhere. Check the seals below the fluid reservoir these can leak. Could also be a perished pipe. My advice drive slow or not at all.
Offline tnewson
« Reply #4 on: 22 February 2009, 19:17 »
yeah... looks like there has been some fluid coming from where the brake cable joins the cylinder... that little nut seems quite wet.. i just hope it aint gonna cost me bomb to be honest...
« Reply #5 on: 22 February 2009, 19:22 »
Seal is probably leaking then where the master cylinder joins the fluid reservoir. top it up for now but get it sorted ASAP
« Reply #6 on: 23 February 2009, 08:32 »
all mk2s have a dual brake system, the front & rear holes on the cylinder are on seperate brake circuits.
