Author Topic: G60 Belts  (Read 1115 times)
Offline 993turbo
  • Too many cars, too little time......
G60 Belts
« on: 18 February 2009, 14:57 »
Hi there...
Im about to change the belts on my G60. The car is standard, with A/C - Power steering....
Im planning to change all of the belts, including timing belt.
-How many belts are there?
-Any tensioner bearings / tensioners to change?
-Any recommended ''upgraded'' parts?? Wider belts or.......
Any input appreciated......
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline 993turbo
Re: G60 Belts
« Reply #1 on: 18 February 2009, 15:24 »
I see some using a 11,5mm charger belt? What is the story with this......?
« Last Edit: 18 February 2009, 16:02 by 993turbo »
Offline DarnPB
  • Formerly Darnpistonbroke
Re: G60 Belts
« Reply #2 on: 18 February 2009, 18:32 »
You will need the cam belt and tensioner, the serpentine belt that drives the compressor and the alternator, the powered steering belt and the aircon belt, although with aircon models, I dont know whether this shares a belt with something else.
The very small charger belt inside the charger is also a good idea.
I have replaced all mine, although I dont have air conditioning. Make a note of the routing for the serpentine belt. Also check your serpentine belt tensioner for fluid. It is like a little shock absorber and the fluid usually disapears after a few years.
Offline 993turbo
Re: G60 Belts
« Reply #3 on: 19 February 2009, 01:19 »
Cheers....
Aircon and Powersteering is shared as far as I can see....
I suppose I will just pop by Aurgi or Norauto to pick up some belts....
 :smiley:
Offline DarnPB
Re: G60 Belts
« Reply #4 on: 19 February 2009, 07:04 »
Cheers....
 :smiley:
Norauto will only supply belts if they fit them. Robbing b@stards. Some B.S about waranty.
Offline 993turbo
Re: G60 Belts
« Reply #5 on: 19 February 2009, 11:37 »
Cheers....
 :smiley:
Que?
I have bought belts there MANY times.....
Offline DarnPB
Re: G60 Belts
« Reply #6 on: 19 February 2009, 12:03 »
I tried to buy a cam belt and tensioner, and they would not sell it to me unless they fitted it. So I walked away and put my business somewhere else. To be honest, Norauto are not that good. Expensive and no knowledge. They could not even charge my aircon properly because they did not have the correct adaptor. But that's just Spain all along. One of the many reasons why I am so desperate to get out of this stupid backward country.
Offline 993turbo
Re: G60 Belts
« Reply #7 on: 19 February 2009, 13:17 »
I agree. Competence is at a VERY low level. But, hey, Im here for the weather, and good weather it is.... Costa del Sol has the best weather in Europe :-)
