Author Topic: Picking up my car 2moro, but a bit unhappy :(  (Read 12217 times)
Offline ifti
Re: Picking up my car 2moro, but a bit unhappy :(
« Reply #50 on: 20 February 2009, 10:22 »
Its an ethernet cable - not an internet cable! Its used for networking, so yes you could connect your laptop to it. Maybe it was used to set something up initially and wasnt used since then?? Not 100% sure....
The rest looks like it may be some cheap bluetooth kit, or then again - its not one of those speed camera/laser signal jammers or somet is it?
Offline bobotheclown
« Reply #51 on: 20 February 2009, 10:45 »
Looks like a third party sat nav receiver to me.
Offline Teutonic_Tamer
« Reply #52 on: 20 February 2009, 11:04 »
I have two toggle bars next to the light switch, one with numbers 1-3 and one with a bar that goes from thin to thick, is that the auto headlight lowering sensor required to legally fit HID's?
OK, the wheel with the bar which goes from thin to thick is just the dimmer for the instrument lighting.  And the other with numbers 1-3 is the MANUAL headlamp beam level control.  It is not an 'automatic' level control, and you will not have the required sensors on the front and rear suspension arms.  So you can NOT legally retro fit Xenons, even if you use the complete OEM Xenon headlamp unit.
Just to confirm my advice, when it is dark, park up about 10 foot away facing a wall (or garage door, petrol station, or whatever).  Turn on your dipped headlamps, and move the 1-3 wheel, and watch the beams go down and up in sync with your thumbwheel.  Then when you are bored with that, look at the back-lighting in the instrument cluster, and move the other wheel, and watch the instrument lights dim up and down.  When doubley bored - drive off or park correctly!  :tongue:
it looks like some kind of reciever or signal enhancer. any ideas?
That is just an aftermarket GPS antenna.  Looks like someone from CeeBeebies applied the glue though!  :shocked:
thats an internet cable but if i plug my laptop into it what am i connecting to exactly?
That is the connector for a dash-top GPS speed camera detector system.
that is the thing thats suckered on to my windscreen and i have no idea what it is. it is connected by a thin cable.
this is a side view of the mysterious sucker thing.
And those are additional 'laser detectors' to link into the GPS speed camera warning device.
So can anyone tell me what these things are for? i do have a parrot connected to the stereo if that helps, i would rip the internet cable out but i dont want it messing anything up. im learning loads just by being on this forum so thanks guys  :wink:
My final guess that those leads and associated gubbins belong to a Road Pilot - www.RoadPilot.co.uk  :nerd:
« Last Edit: 20 February 2009, 11:09 by Teutonic_Tamer »
I feel like a homo
Offline ifti
« Reply #53 on: 20 February 2009, 11:05 »
Third party sat nav receiver stuck down with lots of chewing gum?
Personally I'd remove all this extra stuff and clean up the gum.
Offline ifti
« Reply #54 on: 20 February 2009, 11:07 »
Aha - so I was on the right track with the speed camera detector idea!!! ;)
Offline joesgti
« Reply #55 on: 20 February 2009, 11:40 »
shows that the last owner like to drive fast  :laugh:
GTI MK5
Not the only GTI...........but the best! ; )
« Reply #56 on: 20 February 2009, 11:44 »
Or actually liked to drive slow because he already had 9 points from is last car?  :huh:
I feel like a homo
Offline ifti
« Reply #57 on: 20 February 2009, 12:14 »
Now is that a good or a bad thing for the current new owner!?!
Offline AlanD
  • MK5 2.0T 16v
« Reply #58 on: 20 February 2009, 12:28 »
Id say bad tbh :undecided:
I would try not to read too much into it.
Offline Edition30
« Reply #59 on: 20 February 2009, 13:30 »
Aint that what we all buy a GTI for? Abit of a spirited drive every now and then?
sorry but my vaux looks far better than the mk5 gti, thats why i bought it  :wink: faster too  :grin:  :tongue:
July/08 Pearl Black Golf GTI Edition 30
