Author Topic: DE-CAT DOWN PIPE  (Read 5799 times)
Offline richw911
Re: DE-CAT DOWN PIPE
« Reply #10 on: 17 February 2009, 19:57 »
Fail your MOT I would have thought as well?
Yep
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #11 on: 17 February 2009, 20:16 »
iirc the aum has pre lambda and a post lambda sensors fitted therefore you cant fit a de-cat pipe and like said it would need the warning light coding out whereas the agu can run a de-cat pipe as it only has the (1) pre lambda sensor fitted
2000 Mkiv GTi 1.8T AGU
Offline l3w1s
« Reply #12 on: 17 February 2009, 20:24 »
oh sh!t, prob should of looked in to this a bit more, what so theres no chance what so ever of me fitin this then, its got two holes in it that look a bit like there for sensors, what happens if i did fit it and didnt hook up the sensors?
  • "1.8T AGU"
« Reply #13 on: 17 February 2009, 20:37 »
slim i would say tbh
the sensors need to be fitted on the aum engines the ecu relys on readings from the pre lambda sensor but the post one is just metering in effect what is going out of the exhaust i wouldnt advise running with neither of the sensors fitted
Offline l3w1s
« Reply #14 on: 17 February 2009, 20:40 »
but  if i run it without the sensors will it just f**k up, is that what your saying, cant r-tech do anything bout that ?
Offline bobbarley
  • I'm kind of a big deal...
« Reply #15 on: 17 February 2009, 20:44 »
Why are you so keen to make your car illegal?
  • "1.8T AGU"
« Reply #16 on: 17 February 2009, 20:58 »
basically yes have to speak to nick tbh but dont know if they could i think if you run like myself  the miltek 3"downpipe/sports cat and it throws up the warning light which they can do that can be coded out and have read somewhere about a spacing washer that can be welded onto the lambda boss basically to space the tip of the lambda sensor iirc the aum engine with a sports cat needs to run 200cpi whereas an agu can run 100cpi
Offline sambo
« Reply #17 on: 17 February 2009, 21:23 »
Pretty sure there is a way around this. Some way of fooling the ecu to think it is recieving differant info via the post cat sensor.
If you are a member of ukmkiv.net then PM this member:
http://uk-mkivs.net/user/Profile.aspx?UserID=20877
He has done it and know's how to get around it. :wink:
HTH Sam
« Last Edit: 17 February 2009, 21:28 by sambo »
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 17 February 2009, 21:48 »
I run a decat on my AGU and it's freed the revs up nicely. If I had an AUM I'd got for a sports cat though due to the sensors/engine warning lights
Offline l3w1s
« Reply #19 on: 17 February 2009, 21:54 »
not to good with all this stuff but where do the sensors go, are they attached to the side of the down pipe or something or somewhere completly different, already got engine light on for something else, will it go into limp mode?
