Author Topic: help with a ford  (Read 2213 times)
Offline GOLF_STU
  • THE_GIT
help with a ford
« on: 16 February 2009, 20:34 »
right i got a problem with a friends focus tdci 04 plate its got no power and the fault code came up a boost problem. had a look and cant find any leaks so looked at the turbo and the actuator isn't moving when you rev it but moves if you push it so its not seized  :huh: so wondered if anyone knew of anything?
V TEC KICKED IN Y'ALL!!!
Offline RnP
  • Audi S4 gone, looking for b5 rs4
Re: help with a ford
« Reply #1 on: 16 February 2009, 20:47 »
possibly boost solenoid
Offline GOLF_STU
  • THE_GIT
« Reply #2 on: 16 February 2009, 21:40 »
thats what i was thinking just wanted some back up  :smiley: il nip to the scrappy n see if they got one
Offline danny_p
« Reply #3 on: 17 February 2009, 00:00 »
losss of all power, and no boost    is also  limp home function.    you piss the littel black box off it just holds the wastegate wide open  :sad:
intercooler full of road debri,  iffy maf all worth checking.
take look at airflow  rate if the indicated rate is ether way high or all over shop   its a maf fail
all the VW's have gone bar 1.
Offline GOLF_STU
  • THE_GIT
« Reply #4 on: 17 February 2009, 20:32 »
cool cheers il have a nosy  :cool:
« Reply #5 on: 19 February 2009, 09:05 »
Also worth checking the throttle pedal switch.
