Author Topic: Front Strut Brace  (Read 4002 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Front Strut Brace
« Reply #20 on: 16 February 2009, 14:03 »
LOWER S3 STRUT BRACE FITTING GUIDE
(Lifted from ukmivs):-
Quote
part numbers for leon are exactly the same as for the mk4 golf (prices in brackets are from a stealer)
S3 lower brace  8N0 199 403 B (£12+vat)
riv/cap nut       N90 810 601 (80p+vat) x 2
Screw/bolt       N10 417 601 (53p+vat) x2
washers           N90 477 301 (42p+vat) x2
Me:-
You will need a ratchet & 17mm socket or spanner.
Please note that the part no's were (maybe still??) wrong for the washers, on ETKA (too small to go over the bolts).  I don't think they're THAT important for this bar, but I bought a pack of 10 from B&Q, & I'll post you 2 F.O.C. if you go through with it. :afro:
1)  Off the car, assemble the bar & bolts like this:
  a)  Hold the bar, foam side DOWN (facing the floor).
  b)  The bar is marked with a green 'L' at one end - This goes on the N/S (passenger side) of a UK RHD car.
  c)  Place washers over bolts
  d)  Push bolts UP through the holes of the bar (so the heads are the side of the foam).
  e)  Screw riv caps on (finger tight only).
2)  SAFELY jack car up on stands etc.
3)  Get a mate or a spare jack etc to hold the bar in place.  The bar goes accross the Dogbone mount & there are only 2 holes in which it can screw into.  (Remember. foam side down, L on UK N/S).
4)  You may be thinking that the holes are too loose, as the bar just falls on the floor if you leave it on it's own.  (This is why you need your friend/jack to hold it in place).
5)  With the bar held flat to the car, keep tightening the nuts with your socket.  (Nip up the first side, then go to the other side & nip that one up, then back to the first side & fully tight this time, then finally fully tight on the 2nd side.  What happens is, the riv nuts expand into the subframe & grip tightly to it - This is why you need to hold it flat against the car whilst you tighten. ;)
I will be back later for the upper guide & maybe some pics. :)
« Last Edit: 03 January 2010, 14:52 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline topher
  • Administrator
  • fully functioning
« Reply #21 on: 16 February 2009, 14:22 »
He bought it in a G/B 2-3 years back
it's been in the garage a bit longer than that :grin: original group buy thread http://uk-mkivs.net/forums/t/18118.aspx
« Reply #22 on: 16 February 2009, 14:54 »
:D
No wonder that gaffer tape had welded itself on!!!  :D
