Author Topic: Alternator missing bolt?  (Read 1788 times)
Offline maxp
  • J reg 8v digi gti
« on: 15 February 2009, 19:41 »
Had my car serviced yesterday, the mechanic said the alternator was really loose but said he had sorted it.
After having a look myself im trying to work out if when he tightened it, if he forgot to put a bolt back on? I have no idea if the bit highlighted should actually of ever have one or not.
Thanks.
« Last Edit: 15 February 2009, 19:44 by maxp »
Offline porsche
  • 1989 Mk2 8V GTI & Porsche 911 Carrera
Re: Alternator missing bolt?
« Reply #1 on: 15 February 2009, 20:20 »
Hi,
The threaded part you see is the end of a long allen bolt that goes in through a hole in the timing cover. A 5mm allen key (I think?) tightens it. It wont have a nut on it as it goes into a thread on the bracket that holds the alternator. The head on my one was rounded so hopefully yours is okay.
Offline maxp
  • J reg 8v digi gti
« Reply #2 on: 15 February 2009, 20:59 »
Ok thanks. There was a nut just sat,resting on top of the battery. He said he had no idea and that it was nothing to do with him. Anyone familiar with where it might go (or where it might have come from?!)
« Last Edit: 15 February 2009, 22:15 by maxp »
Offline Benrevs
« Reply #3 on: 15 February 2009, 21:07 »
That could be many, many things!  Have a look and jiggle a few things around, tis the only way!
Offline AdamMk2
  • Beautiful
« Reply #4 on: 15 February 2009, 21:48 »
There was a similar problem on a mk2 I broke mate.
Check the bolt hasnt snapped  partway thus not leaving it long enough to thread in, but making it appear it has trhread and is correct.
The part it goes into after the alternator is threaded.
The bolt had snapped on the 8v I was breaking
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 16 February 2009, 08:40 »
Hi,
Is that blue surround on your grille, what I think it is or is it a wannabe? I can't make out the engine, hence my question.
Offline pedro2682
  • GET IT IN, GET IT OUT, GET IT HOME, GET IT WASHED
« Reply #6 on: 16 February 2009, 08:54 »
Dear Max,
The long bolt is for the alternator,take off your timing casing(the top casing) and about half way down you should see a hole where it should fit in. If you have lost,threaded or sheared the bolt i have a spare one for you, if youneed it.
The small nut looks about a 10mm, if you look at the water pump housing, near the water pump there might been a small threaded bolt sticking out, check to see if the 10mm nut fits on there.
Hope this helps, good luck. :smiley:
Offline porsche
« Reply #7 on: 16 February 2009, 10:29 »
[/quote]
Hi,
It was a turquoise/blue grille stripe, bumper trim & pin stripe. I say was It's now red again!  And yeah its a 89 GTI Digifant.
Offline DarnPB
« Reply #8 on: 16 February 2009, 12:15 »
I thought it may have been the special edition, ie G60 16V. Rare as you like if it was.
Offline edpryce
« Reply #9 on: 16 February 2009, 13:57 »
pretty sure thats 6mm allen key that goes through the timing casing and through the alternator after all my weekend of faffing
that'l save you all of 10 seconds
« Last Edit: 16 February 2009, 15:46 by edpryce »
