Author Topic: annoying oil buzzer  (Read 1120 times)
Offline zoomgti
annoying oil buzzer
« on: 15 February 2009, 18:12 »
On a Mk2 1.8 8v GTI as soon as we put the key in the buzzer starts even with out the engine running? any idea on what is going on as by our understanding senors should not be sending anything back till the engine is started. The car manual states that the buzzer should not go off unless the engine exceeds 2000 rpm. The buzzer continues to go off when started regardless of what the tacho is reading.
Offline danny_p
Re: annoying oil buzzer
« Reply #1 on: 15 February 2009, 18:41 »
clocks may be buggerd then
all the VW's have gone bar 1.
Offline Mr Blue
« Reply #2 on: 15 February 2009, 18:57 »
just to add.
if the oil sensors are disconnected should the buzzer go off over 2k?
mine did not :lipsrsealed:
Offline danny_p
« Reply #3 on: 16 February 2009, 01:08 »
high pressure sender  is  NC  contacts  they open when it has pressure..   disconecting it  turns buzzer off iirc
Offline zoomgti
« Reply #4 on: 17 February 2009, 13:02 »
i have tried disconnecting the senors and it still buzz if you hit the dash board the buzzer changes
Offline rodz22
« Reply #5 on: 17 February 2009, 13:09 »
sounds like a short somewhere maybe in the clocks
Offline zoomgti
« Reply #6 on: 18 February 2009, 11:16 »
Managed to get it to shut up, took the dash out  everything seemed to be tight and in place and no damaged cables.  rebuilt it still had the stupid buzzing noise.  took it off the drive to park it else where  pressed the horn messing around, to make the other half jump and the buzzing has stopped took the car round the block and no noise and the flashing light stops  after 10 seconds of the engine running at ide.
no the bloody stereo has stopped working,  so will be back out to look at that,
Thank you for your ideas to help me sort this
