Golf mk4
Wazzzer
VW GOLF MK4 Fuel cap problem
Topic: VW GOLF MK4 Fuel cap problem (Read 13946 times)
BG-MK4
15 February 2009, 12:38 »
My fuel cap won't open. When I press the release button I can hear that the mechanism works, but the fuel door doesn't open. Is there any way to open it manually?
Seat Leon 20VT4
K666PDP
Here all the time
Re: VW GOLF MK4 Fuel cap problem
15 February 2009, 14:50 »
maybe get some1 to press the button and at the same time try to 'lightly pursuade' the cap to open?just be careful not to damage the paint use plenty of rags to protect the paint as it cud be a sticky locking mechanism?esp with all this bad/cold weather? if it is just lubricate up once opened with some wd40 then some oil?and test it whilst the cap is open if its not that then sorry i have no idea
Rhyso
Global Moderator
Sir Postalot
15 February 2009, 14:51 »
you're going to have to pull back the boot carpet on the fuel filler side
not sure if you have to remove the parcel shelf support
Fire Up The Quattro
sambo
15 February 2009, 15:07 »
I did a how to over on ukmkiv.net a while ago, still works now.
http://uk-mkivs.net/forums/t/115408.aspx
HTH Sam
Sam
AXX power! .. Tinkering has started....
dai-cymru
1989 MK2 16V
15 February 2009, 15:16 »
sounds like the linkage arm has come off/snapped quite easy when you take the carpet out the way,
csny4
15 February 2009, 23:39 »
you need a new release button if you can hear mechanism working i had the same thing easy to fix
jonnyturbo
Forum addict
Reply #6 on:
16 February 2009, 01:23 »
is this a common fault ?
BG-MK4
Reply #7 on:
16 February 2009, 07:37 »
It happened after I got the car from a paint work. They hadn't put the fuel cap right and it was quite stiff. It is already fixed.
Seat Leon 20VT4
Golf mk4
Wazzzer
