Author Topic: indicators - led's  (Read 9676 times)
Offline JMallows
Re:indicators - led's
« Reply #10 on: 18 July 2004, 00:47 »
Find out the current that the circuit will use, then use Ohms law to give the value of th resistor: R=V/I Where R=resistance, V=Potential Difference, and I=Current. Hope this is helpful!
Eh? ???
Sorry, which bit don't you understand?
A clever person solves a problem. A wise person avoids it.
VeeDubGTI16v
« Reply #11 on: 18 July 2004, 16:13 »
its cool i understand. ;)
do i just use one resistor run in series with the 4 led's ???
Mixologist
« Reply #12 on: 18 July 2004, 17:45 »
buy the indicators and cut them up, but yeah they will ahve a resistor or else they will blow up, ask nick he is doing it at uni
Ahem, i doing mechanical, bollox to electrics!!!
Offline JMallows
« Reply #13 on: 19 July 2004, 00:25 »
Cool, sometimes i'm not very good at explaining things!
What do i mean SOMEtimes, Never!
You'll probably need two resitors, one for the left, one for the right. Is that what you meant?  ??? :-\   You want to aim for about 6-7V, no more though. And its V important to have them the correct way round, ie +ve with anode, not cathode, as LEDs can't be reverse biased.
Offline JMallows
« Reply #14 on: 19 July 2004, 00:25 »
Whats wrong with electronics??  ;)  :P
VeeDubGTI16v
« Reply #15 on: 19 July 2004, 16:49 »
its confusing ;D
Mixologist
« Reply #16 on: 19 July 2004, 19:08 »
yeah, you can't see whats going on!!! ???
Offline JMallows
« Reply #17 on: 19 July 2004, 22:38 »
This is true i suppose!!!
Had a (hopefully helpful) thought for you. Wire up the diodes, and then use a tansformer and a potentiometer to find out the best operating potential. Enough to be at their brightest, but not too much they start to go funny colours!!  ::)  I reckon it'll be about 7V, maybe less, probably between 6 and 7. Then us this in the formula. It should all work, let me know if if it doesn't, and if it does, wanna see how good it is!
VeeDubGTI16v
« Reply #18 on: 20 July 2004, 17:30 »
ok cheers for help jmallows. im not gonna do it just yet, ive got loads of stuff to do first before i relocate the indicators (like finish the bumpers :-[ ;D)
cheers
Offline jazzygm
« Reply #19 on: 20 July 2004, 19:54 »
if you are buying the LED's off of somewhere that specialises in selling them, or an electronics company like maplin (www.maplin.co.uk  ;) ) then they will have things such as forward current and forward voltage noted.  Then from R= V/I
Supply Voltage(V) - LED Forward voltage(V)
LED Forward current(A)
Where the supply voltage is errrr... 12 Volts... it being a car!
Always go for a slightly larger (not overly larger!) resistor than needed to protect them a bit, and you need the highest candela rating you can get.
anything else? oh, ive heard that if you gently file the tip of an LED the light will diffuse a bit better. dont try it unless you've got a spare though! and the potentiometer is a good idea... as long as you are very careful, IIRC theres a very fine line between maximum brightness and burning it out! And they need to be the right way round... hence forward voltage  ;)
HTH!  8)
