Author Topic: Clock illumination, tried the bulbs  (Read 1257 times)
Offline veedubmk2golf
« on: 14 February 2009, 20:38 »
ive tried the bulbs but still have no light but am still getting illumination from the heater and electric windows is it known for the switches to be faulty and the switch it it turning all my exterior lights on fine
Offline Benrevs
Re: Clock illumination, tried the bulbs
« Reply #1 on: 14 February 2009, 20:54 »
Assuming you have checked the fuses I would check the switch. I have had one where the slider that runs on the dimmer broke off and shorted it out... eventually setting the car on fire. Well worth checking even if its not at fault! Ben.
« Reply #2 on: 14 February 2009, 22:21 »
yeah checked the fuses m8 yeah believe that if the resister goes in the switch linked to the dimmer that will stop the illumination to the clocks its just strange how im getting light from the heater panel and elec windows
« Reply #3 on: 15 February 2009, 11:05 »
elec window switch lights are always on with the ignition, but the heater slider gets power from the switch same as the other switches and the clocks.  The headlight switch bulb also should come on with the ignition, but almost always blown in a MK2 because of this.  I'd say you have a snapped wire somewhere behind the dash, or all the switches and dash bulbs have blown, which is possible.  Get yourself a multimeter/test lamp, pop the switches out and check for 12v between the grey/blue & brown wires.
« Reply #4 on: 15 February 2009, 11:57 »
thanks will do have seen one on ebay yeah thats probably what it is as some of the switches are not showing illumination so as you said there probably blown as for broken wires behind the dash I have checked that but probably a multimeter will be the best option.
Offline JC
  • Back in the North.
« Reply #5 on: 15 February 2009, 14:17 »
have you checked ALL the fuses ????
are your number plate lights working
I know these things  :embarassed: :lipsrsealed:
« Reply #6 on: 15 February 2009, 16:03 »
hi m8, yeah checked all the fuses and number plate lights are working
Offline JC
« Reply #7 on: 15 February 2009, 16:10 »
not wot i had then.  :wink:
