Author Topic: forge oo7p dump valve  (Read 2327 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: forge oo7p dump valve
« Reply #10 on: 15 February 2009, 14:01 »
how will a 007p help?
on a re-mapped car the std bosch dv diapraghm will eventually split due to the uprated power that you have the forge 007 dv is mainly for uprated cars due to the fact of stronger diapraghm and is specifically manufactured for performance extra boost will soon kill a std dv the forge ones are available in black or aluminium and you can specify  4 different spring rates for the level of your map(ie they are stronger) they are green,yellow red& blue ivor put a post up regarding which springs are for what  :wink:
2000 Mkiv GTi 1.8T AGU
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #11 on: 15 February 2009, 14:59 »
Even standard 150's chew the OEM DV's up, net alone mapped cars!! :D
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
  • "1.8T AGU"
« Reply #12 on: 15 February 2009, 15:17 »
aye your right there ivor funnily enough mine decided to go when i ordered the forge one :huh: :grin: how strange must of known a map was on the cards  :grin: :grin:
Offline barry-gti
« Reply #13 on: 15 February 2009, 16:41 »
cheers mate
