Author Topic: Brakes on a ED30 Vs GTI V  (Read 5008 times)
Offline joesgti
Re: Brakes on a ED30 Vs GTI V
« Reply #20 on: 17 February 2009, 07:33 »
does nobody use the search function  :laugh: :laugh:
R32s are next on my list. i really need them now!!  :shocked:
GTI MK5
Not the only GTI...........but the best! ; )
Offline VeeDubDan
« Reply #21 on: 17 February 2009, 09:43 »
This thread shows a couple of cars with R32 brakes running 17" wheels, although they're not Monzas.
http://www.golfmk5.com/forums/showthread.php?t=72561
18 Golf R Estate, 08 GTI and 03 GTI
Offline Teutonic_Tamer
« Reply #22 on: 17 February 2009, 15:32 »
38.0 psi or 2.6 bar.
I check them every week, it is ingrained.
Don't forget though that numbers on the fuel flap are actually just a 'recommendation'.  That means that those pressures on the flap are a 'one size fits all', for the 'mr average' driver.  If your vechicle loading, or more likely, driving style, actually differs from 'mr average' then it is perfectly acceptable (and legal) to tweak the recommended pressures.  So, because your tyres a wearing more heavily on the shoulders, I would suggest you actually need to increase the pressures on the front a little more.  On my GTI, I actually run the fronts at 42psi, and the rears at 37psi - and get a perfectly level and flat wear rate across the width of the tread.
Just this wheel had been the air supply for 4 good caliper bleeds.
 :smiley:
Yes, yes, I got that!  :tongue:  :smiley:
I feel like a homo
Offline stokeballoon
« Reply #23 on: 17 February 2009, 18:33 »
I have upped the pressures to 40 psi.  I will see how they feel, and what the wear is like over a period.
Cheers for the advice TT.
Offline g60forever
« Reply #24 on: 18 February 2009, 00:07 »
Hello
In spain my friends, have brembo in golf gti mk5, is kit original brembo
2 caliper 4 pistons
2 disc of 330mm
4 Brake Pads
2 Stainless Steel Brake Lines
every new, in spain the prince in ofert is 1300€ 1148libres
whit this kit no problem calipers whit wheels
If you have questions this is my email address: fcomdz2003@yahoo.es
also photho
