Author Topic: G60 Engine Mounts  (Read 4486 times)
Offline 993turbo
  • Too many cars, too little time......
G60 Engine Mounts
« on: 12 February 2009, 00:35 »
Hi
I think my Engine / Gear mounts are shot. The car is a standard 90' Golf GTI G60
-Which mounts to buy?
-Ive heard that usually the front engine mount and the gear box mount go first, not the ''rear engine mounts''? Any comments on this?
- Are there 3 mounts in total (Engine front and rear / and 1 on the gearbox)?
-tips / hints / links to places where I can buy some mounts at a good price....?
Cheers... :-)
« Last Edit: 12 February 2009, 01:12 by 993turbo »
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline danny_p
Re: G60 Engine Mounts
« Reply #1 on: 12 February 2009, 01:13 »
3 mounts in total
1 rear engine
1 gearbox
1 frount mount
frount mount is common fail   ,  gearbox mounts aslo go quite often and both easy fix.   g60 rear engine mount is most expensive and most involved to change but not to bad.   but is most long lived
all the VW's have gone bar 1.
Offline 993turbo
« Reply #2 on: 12 February 2009, 03:28 »
Cheers. Ive put in an order for a front engine mount and a gearbox mount. Ive also ordered the top mounts for the shock struts up front... Hope this will cure my little ''cluncking'' problem.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #3 on: 12 February 2009, 05:15 »
Your clunking problem will almost definately be the front mount. Easy to change. 1 hour should do it. I have just bought all three mounts for my 60. Will fit them when I take the engine out for an extensive service.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #4 on: 12 February 2009, 09:49 »
I had a clunking due to a broken gearbox mount causing the leg that supports the box, that bit that comes up and over, to constantly bang on the underside of teh chassis leg in the ibiza.. 1.3 gearbox mount is solid rubber and about £7 odd from memory
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline 993turbo
« Reply #5 on: 12 February 2009, 13:58 »
Great stuff. I have ordered all the mounts and will replace them.... Finger crossed for a significant improvement....
 :smiley:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #6 on: 12 February 2009, 14:06 »
now would be the ideal time for a bbm style solid front mount.
Offline 993turbo
« Reply #7 on: 12 February 2009, 14:10 »
Ive already ordered. Solid it is, but I doubt its bbm....
Offline Dolly
« Reply #8 on: 12 February 2009, 21:05 »
i put a solid front mount when i fitted my G60, it hasnt seen too much of the open road yet so i cant comment, i have heard mixed opinions. some says its better to fit a solid front mount to stop engine movement and then helps if they is a 4 branch manifold fitted.
and then some say it makes the car rattle and vibrate, and the bolts in the mount can even shake loose?!
Offline Chris-White
« Reply #9 on: 12 February 2009, 21:24 »
The one on my G' is great. Little bit of extra rattle but really not much, and makes the car feel far nicer and smoother. Mines basically identical to the bbm one you get from gwerks, but without the branding on it. Never had any problems with bolts coming loose and i do tend to drive it like i stole it.
