Author Topic: break Lights. Can you fit yourself?  (Read 3009 times)
Offline Steve78
Re: break Lights. Can you fit yourself?
« Reply #10 on: 28 July 2009, 17:07 »
Had a go at fitting the brake light and it was so easy i could not believe it. Thanks for the free advice.
My near side brake light has gone, how easy is it?
Offline TagnuT
  • Edition 30
« Reply #11 on: 28 July 2009, 17:19 »
Dead easy,
1. Slide part of the boot lining trim away from the boot opening ( you will see a slash in the material)
2. Pop off the connector with a screw driver, put the screw driver in the slot.. The connector was blue in my case.
3. Unscrew the two nuts (10mm I think). Take care not to drop them behind the trim.
4. Slide light unit out.
5. Unclip bulb housing.
6. Replace bulb.
Look at http://www.powerbulbs.com/ if you don't know what size of bulb you need....
Bye Bye Edition 30
Offline _Adam_
« Reply #12 on: 28 July 2009, 22:55 »
i meen no offence to anyone at all, but sometimes i get a bit baffled at people struggling simple tasks, how much money do i save myself doing loads of sh!te myself and doing a good job of it too?  :shocked:
Offline Steve78
« Reply #13 on: 29 July 2009, 09:18 »
I haven't done it before and assumed people on here would have done.  People shouldn't be afraid to ask questions on here, isn't that the point of this forum?  Also, I simply don't have the time to fiddle around with it trying to work out what to do, so I thought I'd ask what the procedure was.
Offline _Adam_
« Reply #14 on: 29 July 2009, 20:55 »
as i said i meant no offence :huh:
Offline the dude
« Reply #15 on: 29 July 2009, 22:51 »
Hi I have mark 5 gti and was quoted £65 from Arnold Clark to replace bulb and fit back left brakelight. Is it easy to fit yourself? thought this quote was way to high. Any ideas what bulb size standard, how much etc.
We can show you how to put petrol in as well if you need advice on that!  :drool: :wink:
