Author Topic: KR cams?  (Read 2634 times)
Offline Roverdose
  • So long and thanks for all the fish!
KR cams?
« on: 03 February 2009, 01:45 »
I was chating to my mate and he said i could get more power out of my 1800 kr if i put 2 exhaust cams in it, i have another cam but he said there was an issue with setting the new cam up, aparently a vernier pully isnt enough, does anybody know of this mod? any detailes would be greatly appreciated!
Ian
Re: KR cams?
« Reply #1 on: 03 February 2009, 09:48 »
yes the end sprocket needs taking off and a new keyway cut, for all the effort & costs a decent set of aftermarket cams could be purchased though, or maybe even a set of ABF cams.  The abf cams are generally regarded as 'better' but it depends who you ask, some prefer the curve on the krs :)
Offline Roverdose
Re: KR cams?
« Reply #2 on: 03 February 2009, 09:54 »
hmmmm, i was only gonna do it if it was relitivly easy sein as i gotta do cambelt and put my shiney rocker cover on i thought might as well, mite see if i can lay my hands on some second hand aftermarkets, TO THE WANTED SECTION!
cheers dude  :wink:
Re: KR cams?
« Reply #3 on: 03 February 2009, 10:19 »
yeah there was a guy on cgti that did em for a while (hotgolf) but the cams are so hard it kept killing his grinding bit/tool/whatever he used to make the keyway so he stopped doing em in the end.
Offline danny_p
Re: KR cams?
« Reply #4 on: 03 February 2009, 11:35 »
need one of them   not sure who makes them tho
all the VW's have gone bar 1.
Offline Roverdose
Re: KR cams?
« Reply #5 on: 03 February 2009, 12:15 »
when you said about power curves, i would like a bit more bollocks low down cos pulling away the car tends to shudder a little bit when your trying to pull up a incline, my streets full of old people so i do like to keep the revs down when leaving, id also like a bit more top range and a fair bit more mid range and id be happy, will cams sort this out for me? im not after massive power, just want to make it a bit more user freindly cos it is quite hard work driving a standard 1800 attached to the bulbus lump that is a corrado!
Re: KR cams?
« Reply #6 on: 03 February 2009, 12:49 »
zer vas a recent discussion on clubgti, wasnt really much in the way of outcome though:
http://clubgti.co.uk/forum/showthread.php?t=173287
