por 15 is worth the extra money, even if you slap it on wi a brush willy nilly the finish turns out nice. It dries hard, almost like a plasticy coating and is very tough. But it comes off nicely with a wire brush on a drill too, unlike some undercoatings that dont fully dry, these end up clogging the drill.
You can even get a thicker version called 'po patch' which is perfect for use as a seam sealer, now that stuff is the nadgers.
but as with all stuff really surface prep is key, por also do etch prime and rust remover products, which help get the best finish. I just sprayed a bit o primer on the bare metal then slathered the por15 over the top willy nilly, so far its stayed on nicely
