Author Topic: Power loss at 2500 revs  (Read 17016 times)
Offline Teutonic_Tamer
Re: Power loss at 2500 revs
« Reply #40 on: 05 February 2009, 10:47 »
I've looking into this... not sure how easy it is .
The parts list I have so far... although no guide
1 x 06F 129 627 H - Intake Pipe  - Retains Stock Engine Cover
1 x 1K0 145 845 A - Pressure Hose
2 x N909 265 01 - Clamp
2 x N906 871 01 Spring Type Clip
1 x 06F 145 751 - Intermediate Flange
3 x N101 961 03 - Bolt, Socket Head
1 x N015 082 13 - Hexagon Nut
1 x 06F 145 383 L - Holder
1 x 1K0 145 693 B - Air Circulation Pipe
1 x 1K0 145 770 P - Air Pipe
Wiring
1J0 973 822A - 2 Pin Brown Flat Contact Housing
000 979 134 - Single Wire 1.0mm
1J0 973 722A - 2 Pin Black Flat Contact Housing
000 979 133 - Single Wire 1.0mm
N 107 324 01 - Corrugated Pipe 4.5mm x 2
N 906 819 01 - Corrugated Pipe End Piece 4.5mm x2
Well crack on then, with a full 'how-to' guide by the weekend!  :lipsrsealed:  :evil:
 :grin:  :grin:  :grin:  :grin:
I feel like a homo
Offline LaserBlue
« Reply #41 on: 05 February 2009, 17:30 »
Collected the new valve today, fitting it soon.
feels alot more heavier than i thought it would, feels good quality.
Offline LaserBlue
« Reply #42 on: 06 February 2009, 14:19 »
Well i went to the GermanAutomotive and they are asking £115!!!
Also tried VW, they want 2hours labour at £155!!!!
Gonna drive an hour upto Awesomegti, £49 inc VAT  :smiley:
Economy must be bad for some companies..
Offline AlanD
  • MK5 2.0T 16v
« Reply #43 on: 06 February 2009, 16:09 »
Same here. VW wanted 2 hours to fit my Forge one, just crazy.
Got recomended a local place to me by WhiteGTI and he only wanted 1 hour @ £45 and he owns a veeery nice blk MK5 himself.
Offline neg
« Reply #44 on: 06 February 2009, 16:12 »
Try a place called Solo in Burton - he's a VW man.
Offline LaserBlue
« Reply #45 on: 06 February 2009, 17:57 »
Well im defo going awesomegti, im gonna wait til week after next as i might get some other parts installed aswell..
Will driving around with the boost fault cause any further damage?
Offline bacillus
« Reply #46 on: 06 February 2009, 19:29 »
Just take it easy as if you get the turbo to boost up, it'll never make the requested boost and will be working overtime to try to reach it.
Without traction power is nothing!
Offline winrya
« Reply #47 on: 08 February 2009, 09:37 »
TT would it be possible for you to check this out for me?
"ETKA lists this for the Jetta, and the old G valve for the GTI.  Weird"
And also listed for the passat from 05 and the eos??
I presume the jetta is the tfsi and not the newer type. I'm told the passat is also listed for the same part?  I didnt get it done thursday due to the snow but this new dv seems to be the most popular mod out there at the moment and many are taking their forge ones off to replace with these?
Thanks
Ryan
« Last Edit: 08 February 2009, 17:39 by winrya »
Offline AlanD
  • MK5 2.0T 16v
« Reply #48 on: 08 February 2009, 10:33 »
Replacing their Forge one with G spec VW valves? Whats the point, Forge one is just as good if not better.
Silly people wasting money imo.
Offline winrya
« Reply #49 on: 08 February 2009, 10:45 »
No this one alan http://www.golfmkv.com/forums/showthread.php?t=75232
Its apparently performing better than the forge but TT has said since its not yet listed as the latest update for the tfsi then its a bad idea and suspects its only designed for the newer tsi engines which have a different turbo?
