Author Topic: Power loss at 2500 revs  (Read 17062 times)
Offline Teutonic_Tamer
Re: Power loss at 2500 revs
« Reply #20 on: 03 February 2009, 12:36 »
revision G is much better, unless there is this new one the US guys were on about.  Otherwise a Forge will do the job - more money mind.
But the forge one should last a lifetime...
Erm, nothing lasts a lifetime.  It may have a lifetime warranty (limited too  :wink:), and if sommat on the Forge DV brakes during normal use, then Forge will repair it or supply a new.  But it aint indestructable.
I feel like a homo
Offline Komenda
« Reply #21 on: 03 February 2009, 12:47 »
And you still need to service the Forge DV
« Reply #22 on: 03 February 2009, 12:49 »
Exactly.  At least the OEM G versions are fit and forget.
I feel like a homo
Offline LaserBlue
« Reply #23 on: 03 February 2009, 16:27 »
i think ill go for the OEM G VERSION? any part number?
how ideas on fitment prices?
Im gonna go see Neg when hes free, as he has the vagcom so hopefully it is only a valve, its not much boost loss but is noticeable
Offline topher
  • Administrator
  • fully functioning
« Reply #24 on: 03 February 2009, 16:30 »
VW have FINALLY got rid of the stupid plastic diaphragm in their diverter valves? F*ck me.. only took them 10 years of failing to get that right.
« Reply #25 on: 03 February 2009, 16:43 »
Is yours a standard GTI, or an Ed30 - as the actual location is different?
For the standard GTI and the Ed30, it is "06F 145 710 G" - which fits engine codes AXX, BWA, BPY and BYD.  Pricewise, for just the part from a main dealer, look at around £22 plus vat.
Fitting-wise, on the standard GTI, it is bolted directly onto the turbo housing, at the rear of the engine - and is a tad fiddly to get to.  On the Ed30, it is remotely mounted at the front of the engine near the top, an is a doddle to get to - probably a 5 minute job!
I feel like a homo
Offline LaserBlue
« Reply #26 on: 03 February 2009, 17:21 »
Ive got a standard GTI... £20-£30 aint bad, im guessing it will take an hour to fit at vw so around £70
I might try www.germanauto.co.uk as my friend takes his BMW and says the service is excellent.
« Reply #27 on: 03 February 2009, 17:32 »
And they are a member of the "Good Garage Scheme" too (with some excellent feedback as well!  :cool:), so that should give you some piece of mind too.
I feel like a homo
Offline neg
« Reply #28 on: 03 February 2009, 17:55 »
I am tempted with Germam Auto for some work I need doing - my mate popped round last night and he recently took his (my previous) Leon Cupra R there - he was impressed and price was good too.  Then even collected his car !
Fitting is a pain - you really need to get the car on a ramp (or use a pit) - 30-40mins tops.
Offline keyser
  • They're only the band the beatles could've been.
« Reply #29 on: 03 February 2009, 18:46 »
I took mine to an independent and he charged £30 for a half hour job.  It really does need a ramp as it's a b*****d to get to on the standard gti.
MK5 GTI, manual, silver, dirty pipes.
