Author Topic: Power loss at 2500 revs  (Read 17063 times)
Offline Teutonic_Tamer
Re: Power loss at 2500 revs
« Reply #10 on: 02 February 2009, 09:06 »
Get a Forge one, bit more money but should outlast the car (especially if you want to remap later on).
I am not doubting the quality (along with the bling factor) of the Forge valve.  However, with the current "G" version, VW seemed to have nailed the reliability issues of the earlier versions.
If you want the OEM look, and have a K03 motor, then re-site the valve to the front of the engine for a fraction of the cost of the Forge - and I would reckon that any troubles (providing you do have the "G" valve) would be avoided.
I feel like a homo
Offline winrya
« Reply #11 on: 02 February 2009, 13:26 »
Certainly sounds like the diverter valve. Vw have revised it again with the diaphram removed so high boost doesn't rip it anymore. I'm having it fitted on thursday as a precaution. £38 + vat
http://www.golfmkv.com/forums/showthread.php?t=75232
Ermmmmm - how can that be newer than the current "G" version????  :rolleyes:  Volkswagen do tend to know the correct order of letters in the alphabet!  :tongue:
<f/x on - mumbles>fcukin thick yanks<f/x off>
It's not a supercession in the typical sense, where the part goes from an A to B to C, like the original "G" valves were doing. It's a completely new PN that everything's being changed over to, so you can't just call it the "D" rev, since it's a completely different part number than the prior valves. There's a "D" rev of the 06F, and the "D" rev of the new 06H.
« Reply #12 on: 02 February 2009, 15:19 »
OK, I missed the change in part number - but that just confirms that this new valve is actually for the new Audi valvelift TSI engine (which is prefixed "06H").  It wont fit in our TFSI engines - if it were designed to fit our engines, then it would still have an 06F part number.  :nerd:
So I am still right about the yanks lack of intelligence!  :smug:  :smug:
I feel like a homo
Offline winrya
« Reply #13 on: 02 February 2009, 16:07 »
But just to confirm, it does fit both tfsi and tsi engines
Offline LaserBlue
« Reply #14 on: 02 February 2009, 16:13 »
well ive been to the dealers, they want £70 to do a diagnostic check on the car as it takes 1hour :huh:!!!!
Offline neg
« Reply #15 on: 02 February 2009, 18:09 »
Screw that!  I have vagcom  :wink:
Offline LaserBlue
« Reply #16 on: 02 February 2009, 22:19 »
If it is just a valve.. which is the most favourable recommended?
i will be keeping the car for a few years yet so want something durable unlike this vw one that has last only 25000 miles!
Offline neg
« Reply #17 on: 02 February 2009, 22:26 »
revision G is much better, unless there is this new one the US guys were on about.  Otherwise a Forge will do the job - more money mind.
Offline bacillus
« Reply #18 on: 02 February 2009, 23:07 »
But the forge one should last a lifetime...
Without traction power is nothing!
« Reply #19 on: 03 February 2009, 12:34 »
Sorry, but I have to strongly disagree.  If it were to fit the TFSI, then it would DEFINATELY start with 06F.  VAG part numbers are not 'forwards compatible'.  :rolleyes:
EDIT: checked ETKA - it categorically is NOT listed for any TFSI engine.  It ONLY fits the TSI engine which has a completely different make of turbo!!!  :rolleyes:
« Last Edit: 03 February 2009, 12:40 by Teutonic_Tamer »
I feel like a homo
