Author Topic: HELP! Clutch cable clip that attaches to release lever snapped  (Read 2771 times)
Offline colourconcept
pulled into drive and pressed cluth &  heard somthing break.looked under hood and found several parts on the floor. WTF!
found that clutch cable isnt broke but the clip that joins the cable to the release arm/lever was missing.
where can i get diagrams or pics of these parts and how can i repair it
THANKS
Offline boxer1968
Re: HELP! Clutch cable clip that attaches to release lever snapped
« Reply #1 on: 01 February 2009, 19:33 »
and the  car is a? would help
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« Reply #2 on: 01 February 2009, 19:38 »
breakers yard
« Reply #3 on: 01 February 2009, 19:42 »
soz boxer mk3 golf gti 2.0 8v
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 01 February 2009, 19:43 »
gsf & euro sell these pieces.... you'll possibly need the clutch arm ratchet and green cover too as when the ratchet breaks/cracks you lose all the pieces listed
and finally it would be wise to replace the cable as there never the same when they fully extend!!
« Reply #5 on: 01 February 2009, 19:53 »
arm and green cover still good, just missing bits to connect cableto the arm
and how do u get the cable back into the arm?
  • Back in a Mk3...
« Reply #6 on: 01 February 2009, 19:59 »
does the arm still feel tensioned? as under the green cap there is a rachet which snaps.....this makes the pedal drop to the floor and the cable ping all the bits off the end!! (and to remove the cover you'll bend it and need to replace!!)
but if theres still tension, put a jack under the arm and very slowly/gently lift the arm until you can locate the cable! I've done a few over the years this way  :wink:
Offline boxer1968
« Reply #7 on: 01 February 2009, 20:07 »
gsf are good as stated already plus free postage at moment
« Reply #8 on: 01 February 2009, 21:01 »
the arm lifts up till 9.00 position and then stops, is this the point im guessin where tension kicks in becuase it needs to go higher for the cable to fit back in?
  • Back in a Mk3...
« Reply #9 on: 01 February 2009, 22:50 »
yeah thats similar to mine but before this you should feel the spring that tensions it all up....
