Author Topic: Compression Nightmare.  (Read 5491 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Compression Nightmare.
« Reply #20 on: 31 January 2009, 13:11 »
Good luck with the work you have set yourself. Even if you end up junking the engine, the experience you will gain from ripping the unit apart will be invaluable and hopefully give you an understanding of what other people on this forum are on about when it comes to motor tech talk.
Keep the questions coming. You may get differing opinions, but you will get the idea.  :smiley:
Offline Bjork
« Reply #21 on: 31 January 2009, 14:30 »
Yeah cheers. Gonna be one steep learning curve!!!
I am looking forward to it in a way for the experience. It's just daunting but I guess you've gotta start somewhere.  :smiley:
Offline mattkh
« Reply #22 on: 31 January 2009, 15:26 »
... Good advice on the wd-40, I'll do it everyday leading up to stripping it off.
Hi
Instead of wd40, use a penetrating oil like 'Plus-gas'
 or '3-in-one Penetrant spray'.
Offline Bjork
« Reply #23 on: 31 January 2009, 16:27 »
Hi
Brilliant......I'll get some.  :smiley:
Offline Ben Lessani
« Reply #24 on: 31 January 2009, 16:53 »
3 of my manifold studs sheared, and two were completely round and inaccesible - they had to be dremeled off.
I had to resort to a pack of stud extractors to get the snapped studs out!
Might be worth investing in those Irwin nut extrators if things go wrong ;)
Offline Bjork
« Reply #25 on: 31 January 2009, 17:19 »
I'll look into that, cheers for pointing it out.
Offline danny_p
« Reply #26 on: 31 January 2009, 19:40 »
6 sided sockers are very usefull,   but a couple are spanner only :(    if the nuts are really bad leave them and  undo the downpipe and lift the head off with mani attached
all the VW's have gone bar 1.
Offline Village Idiots
« Reply #27 on: 01 February 2009, 10:06 »
Would definately drop the exhaust and take the manifold off with the head. No need to remove it unless you are changing it.
Offline Bjork
« Reply #28 on: 01 February 2009, 11:07 »
Think I might change the head. Got a spare one so might see which looks in better nick.
Offline Conker
« Reply #29 on: 01 February 2009, 11:25 »
I tried to do that but there wasn't just enough room to slide the exhaust out, and I didn't want to start taking the sub frame to bits.  In of terms of undoing the downpipe at the flexi-joint thingy, those bolts look even worse than the manifold one's!  (On mine anyway).
Still a good alternative though!
