Author Topic: Top mounts  (Read 3443 times)
Offline Shady Pioneer
  • graphic designer.
Re: Top mounts
« Reply #10 on: 29 January 2009, 23:35 »
Thing I don't get are those little silver disks on them, is that ok? I don't particularly want to put those ones on if in 2 days later I can get the VR6 ones on. Will my ones I got now be ok? Maybe need a tighten?
Offline boneybradley
  • Back in a Mk3...
Re: Top mounts
« Reply #11 on: 29 January 2009, 23:39 »
the silver discs...do you mean the bearings?? as you need them!
  • graphic designer.
Re: Top mounts
« Reply #12 on: 29 January 2009, 23:40 »
The one's in the first link I posted, that's almost identical to the ones I have, so I'll assume they are the bearings lol! If I were to have those ones put on, which way does the plate go? Face up or down?
  • Back in a Mk3...
Re: Top mounts
« Reply #13 on: 29 January 2009, 23:48 »
them discs are different to mk3 parts..... bin them and use your mk3 one's (as long as the bearing isn't integral!) it could be worth using mk3 vents for simplicity
  • graphic designer.
Re: Top mounts
« Reply #14 on: 29 January 2009, 23:53 »
I'm a bit buggered really. I'll have shoot around Yeovil tomorrow and see if I can find anywhere selling top mounts, with any luck..I'll get some, then it's jacking the b!tch up and taking off the suspension :(
Offline shepgti
Re: Top mounts
« Reply #15 on: 30 January 2009, 00:28 »
so what have you got on it at the moment then?? those mk2 ones?
  • graphic designer.
Re: Top mounts
« Reply #16 on: 30 January 2009, 00:35 »
No some standard Mk3 ones, GTI ones I believe.
Offline shepgti
Re: Top mounts
« Reply #17 on: 30 January 2009, 00:54 »
then whats the problem with them???
Offline bobbito
  • Hammer and Chisel Engineering
Re: Top mounts
« Reply #18 on: 30 January 2009, 03:30 »
GSF will sort you out, find your local one and pick em up, about 20 with vat iirc. U need vr6 ones as they can take the beating a lowered car will give much better than gti ones. Stay away from generic gti/gl/16v/vr6 ads on ebay. they all fit each other but any thing other than vr6 ones on a vr6 die quickly due to the weight of the engine. plus the quality of the ebay ones is v poor, unless are stated vag ones.
I wouldn't use the mk2 ones, its not worth the hassle.
Re: Top mounts
« Reply #19 on: 30 January 2009, 08:05 »
Shady, order the ones in the link I posted, then wait for them to arrive not going to hurt for a day or 2.
Mk2 ones will not fit.
