Author Topic: Anyone care to explain whats happened here?  (Read 2333 times)
Re: Anyone care to explain whats happened here?
« Reply #10 on: 26 January 2009, 08:51 »
would havign the throttle wide open make any difference to how wide the afm opens? becasue if not it wont do anything on a digifant either, since the idle & full throttle switches are on the same circuit.  Unless the ECU sees a wider angle on the afm flooring it with engine off would look just the same as throttle shut to the ecu.
