Author Topic: revised my n249 mod  (Read 3426 times)
Offline northeast_gti-t
  • "1.8T AGU"
revised my n249 mod
« on: 22 January 2009, 22:35 »
Hi posted some pics awhile back of the n249 mod i did and also to jonnyturbos golf :afro:
well the other day ordered some silicon hose of the "bay" and when i got my climate/interior light issues sorted my hose arrived the same day so decided i may as well get that done to :afro:
the revised look:
Happier with this now  :smiley:
matt
2000 Mkiv GTi 1.8T AGU
Offline evil genius
Re: revised my n249 mod
« Reply #1 on: 22 January 2009, 22:44 »
sorry to sound a dumb ass but hwat does this mod do?
i always see people post on scn that they have done it but nobody ever sats what it does?
thanks alot
ian
  • "1.8T AGU"
« Reply #2 on: 22 January 2009, 23:11 »
Hi Ian
no worrys mate the n249 mod just basically diverting vacuum from the fuel pressure reg (fpr) into your dv valve having done the basic i decide that the vacuum resovoir may as well be completely removed and another tee piece put into the vac line and the vac pipe tee"d into that the original pipe to the top of the dv valve is blanked off and iirc the vac resovoir is used with the esp/asr function just stores/creates the vacuum from the dv valve in doing the mod its just taking the vacuum straight from the frp to the dv one of the reasons in doing this is to overcome the slight "hesitancy" when accelerating on std/mapped cars in doing this it can/does cure the issue
:afro:
matt
kcolevol
« Reply #3 on: 22 January 2009, 23:13 »
Hi, i have done this mod, are you not supposed to block the old dump valve line or does it not matter either way? Just that your still using the N249 valve this way surely?
Offline evil genius
« Reply #4 on: 22 January 2009, 23:18 »
just thought id search google for the mod and one of the first one that came up was your post on ukmkivs when you did the mod originaly lol
i asked the saem in that thread too, you say the AGU dosnt have unit fitted :sad:
oh wel
thanks
ian
  • "1.8T AGU"
« Reply #5 on: 22 January 2009, 23:29 »
Hi, the pipework n vac side of the n249 are removed but iirc there is some sort of electrical sensor within the system which is left as it is,blocking the old dv line doesnt matter as such as you run a vac line from your fpr
matt
kcolevol
« Reply #6 on: 22 January 2009, 23:31 »
No worries, just didnt want to get anything wrong lol, thanks. Im happy now lol.
  • "1.8T AGU"
« Reply #7 on: 22 January 2009, 23:31 »
oh wel
thanks
ian
hi ian ah right i can remember now n yes as for the original post it looks a bit different to that now thats correct the AGU hasnt got that fitted lucky you :afro:
matt
  • "1.8T AGU"
« Reply #8 on: 22 January 2009, 23:33 »
Nice one good to hear :afro:
matt
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 22 January 2009, 23:33 »
toph's tip of the day.. be very careful when tapping into the vac from the FPR, make sure everything is TIGHT and secure before you fire the engine up. Leaking fpr vac = lean running = detonation = byebye pistons.
