Author Topic: And it begins...cambelt went on the motorway :(  (Read 3274 times)
Offline twistedblack69
  • Proud mk2 user and abuser
Re: And it begins...cambelt went on the motorway :(
« Reply #10 on: 22 January 2009, 00:00 »
I've just read up on it, and apparently the only interference engines in the mk2's were the 16v engines. Wtf!! How did this happen??
Offline Ben Lessani
« Reply #11 on: 22 January 2009, 00:00 »
Unless he's running a lairy cam - I've heard that could affect it, not the duration, but the lift.
How do you know your valves are bent - I take it you can't turn it over by hand?
« Reply #12 on: 22 January 2009, 00:02 »
My dad's a mechanic, he was taking it apart earlier, I don't have the foggiest. Apparently the belt actually jumped the pulley or something.
Offline Ben Lessani
« Reply #13 on: 22 January 2009, 00:06 »
That's some amazingly bad fortune if it has bent a valve.
But take this opportunity to replace the valve stem seals and overhaul the tappets - saves doing it twice.
Or even stick in a 268 cam, a quick port and polish and a 2.0 lump :evil:
Offline danny_p
« Reply #14 on: 22 January 2009, 00:24 »
i've droped a belt on an 8 valve before  and nothing bent  it just  coughed and farted to a hault,     if 16v or 20v drops belt  ouch
all the VW's have gone bar 1.
« Reply #15 on: 22 January 2009, 00:56 »
He said the belt jumped the cam or something...I'm not sure, I'm trying to slowly learn haha but I am known throughout my circle of close friends as the one that has the luck with cars........that's sarcasm btw  :embarassed: :embarassed: lol
Offline pro-biotic
« Reply #16 on: 22 January 2009, 01:04 »
x 2
tell your old man to stop, put a belt on and try the engine.
your old man means its jumped the cam sprocket.... it will be futile to strip it down TBH
Offline billinjah
« Reply #17 on: 22 January 2009, 02:09 »
all 4 cylinder vw engines are interference i thought? pg's certainly are.
Offline Ben Lessani
« Reply #18 on: 22 January 2009, 08:42 »
I'm trying to slowly learn...
Look here http://auto.howstuffworks.com/engine1.htm, in the diagram, P (crank) and I (cam) rotate in harmony - this is ensured from your timing belt. If the belt snaps, it means that the piston (N) is at risk of hitting the valve (A).
In that animation, the engine could be interference - unless the piston crown was recessed, it would impact the valve.
« Reply #19 on: 22 January 2009, 09:07 »
x 2
Yup tried it
