Author Topic: JamieGTi - "Scrub to Dub Mk4 Project"  (Read 12409 times)
Offline jv
  • Administrator
« on: 21 January 2009, 16:05 »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline JamieGTi
Re: JamieGTi - "Scrub to Dub Mk4 Project"
« Reply #1 on: 21 January 2009, 16:57 »
Thanks jv.  :smiley:
Project "Scrub to Dub"
Well my project is my current daily.
A 1999 Mk4 GTi Turbo
It's got scratches and dents, a few pages full of faults on vagcom and it's got a few mods i'm not keen on.
I plan to over the next 12 months update this thread whenever I make progress and hopefully report on my fixes whilst making a few DIY guides to fixing them.
Below are the results from my VAG COM Session as dated.
Quote
Friday,16,January,2009,17:44:15:55873
VCDS Version: Release 805.2
Data version: 20090111
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 183860km/114245miles
Address 01: Engine        Labels: 06A-906-018-AGU.lbl
   Part No: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
            P1602 - 35-10 -  -  - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-10 -  -  - Intermittent
00561 - Mixture Adaptation
            14-10 - Adaptation Limit (Add) Exceeded - Intermittent
Readiness: N/A
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
4 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            16-10 - Signal Outside Specifications - Intermittent
            04-10 - Mechanical Malfunction - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 02 AIRBAG VW5       0003
   Coding: 12338
   Shop #: WSC 00028
2 Faults Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
            37-00 - Faulty
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
   Part No: 1J0 920 921 A
   Component: A4-KOMBIINSTR. VDO V16
   Coding: 05442
   Shop #: WSC 00028
   Part No: IMMO
   Component: IDENTNR: VWZ7Z0X1772518
   IMMO-IDENTNR: VWZ7Z0X1772518
No fault code found.
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4U Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 04938
   Part No: 1J2959802C
   Component: 4U Tõrsteuerger. FS0002r
   Part No: 1J2959801D
   Component: 4U Tõrsteuerger. BF0002r
   Part No: 1J4959811C
   Component: 4U Tõrsteuerger. HL0002r
   Part No: 1J4959812C
   Component: 4U Tõrsteuerger. HR0002r
4 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 -  -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 -  -
00934 - Electric Window Motor; Rear Left (V26)
            62-00 - No or Incorrect Adjustment
End   ---------------------------------------------------------------------
Current modifications are:
Lowered 40mm on some cheap springs
BSA 17 inch Livewire wheels
Debadged front grill with inserts that arn't smoothed over and stick out like a saw thumb.
The car doesn't look too bad from the outside but when you get close to it you can spot the defects.
When its finished i'm hoping for 200+ bhp and show car status. Maybe not show winning status but a few subtle OEM+ mods to set it off nicely.
Here is the car as it stands now.
I will update as much as possible, Hope it provides fun reading for you all  :smiley:
Offline JamieGTi
« Reply #2 on: 22 March 2009, 13:44 »
UPDATE
Fixed rear window regulator motor myself thanks to the guide found on here!
Anyway...
Decided that if I was going to use my debadged grill I'd need to get it smoothed properly into the bonnet which I can't afford. Instead I decided to spray my old badge black. It's a popular mod on mk4's and I think it looks decent
All images are clickable thumbnails, Click image to enlarge
Existing grill with rusty insert and poor spray job
badge in primer
grill sprayed and badge fixed in position
Old grill fitted
Think it needs another coat but happy with it at the mo, planning anni lights next to give it more of a darker look. What you think?
Offline JamieGTi
« Reply #3 on: 22 March 2009, 13:49 »
Update
Bought a BMC CDA from Edition 38
I needed a union from the MAF to the CDA so I bought a rubber reducer
Here it is installed
CDA intake very close to standard intake - planning to get silicone hose from the cda to stock intake
Much better sounding and noticed better performance especially 3k+
Offline JamieGTi
« Reply #4 on: 18 May 2009, 14:05 »
Quick update
Been busy fixing and using as a daily. For its age and mileage done a 500 mile round trip without skipping a beat!
I fixed the following which i'll put pics on as soon as I can find cable.
New discs & pads all around
21mm rear spacers
Replaced ARB bushes as they were in terrible condition
Replaced ECU coolant sensor
Replaced Airbag module
Replaced Wheel speed sensor
Feels like a brand new car now, much better mpg and feels so much smoother!
I've bought a set of HID's off ebay so waiting to install them and an Audi TT short shifter.
Pictures to follow
