Author Topic: 1.3 warm air valve  (Read 1444 times)
Offline daniel-1986
1.3 warm air valve
« on: 19 January 2009, 11:28 »
how would i go about wedging the warm air valve in the 1.3 air intake.my car starts spluttering after being in the motorway for while when i wasnt using the warm air pipe and now i have have though i dont have the manifold shield i wedged the pipe in like this
but seems that the valve aint opening and it seems to controlled buy a little vacuum pipe from the airbox
Re: 1.3 warm air valve
« Reply #1 on: 19 January 2009, 15:32 »
you need to fit that shield, nothing I did would stop this from happening on my 1.6 till i put the shield on!  A couple big jubilee clips round the shield & mainifold will hold it on if all the bolts are knackered.
ids that pic of your actual airbox? if so thats never going to work as it needs to be a sealed unit to draw nothing but warm air.  There should be a vac nipple on the carb somewhere which runs to the air temp sensor on the bottom of the airbox, then there is another pipe to the nipple in your picture.
« Last Edit: 19 January 2009, 15:34 by rubjonny »
