Author Topic: Petrol Gauge Fail  (Read 2316 times)
Offline bondbill2k2
Petrol Gauge Fail
« on: 14 January 2009, 00:31 »
Well went for a drive in the golf today, soon as i turned the ignition on i noticed the petrol gauge was totaly empty,didnt move.
Odd...sure was just above the red last night  :sad:
So i went to the petrol station put £10 just for some short journeys...still nothing.
Any idea why this may be? Possible loose connections or a fuse?
Offline Shady Pioneer
  • graphic designer.
Re: Petrol Gauge Fail
« Reply #1 on: 14 January 2009, 01:11 »
Mine lies to me, I put £20 the other day, took it to just under half way, drive a little bit, it goes down to a quarter..bit of a drop. Next day get in the car and it's back up, I probably got a full tank based on mine f**king up lol!
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
« Reply #2 on: 14 January 2009, 09:09 »
check the fuse first if not that check the fuel sender leads on the pump under back seat if wiring looks ok remove fuel pump n sender n see the float is still attached.
Offline bondbill2k2
« Reply #3 on: 20 January 2009, 13:26 »
what fuse is it? Looking in the original car manuala nd says isn't a fuse for sender from what i can see.Checked the sender and couldnt see wires on it looked sealed.
When ignition is turned the needle raises a few mm's so its basicaly not below the minimum but wont go any higher
Offline bondbill2k2
« Reply #4 on: 08 February 2009, 23:58 »
Im used to not having a petrol gauge (failed in my mk2 and my mini)
Ive checked the sender and it appears 100% ok and a good clean connection.
You say check the fuse but looking in the car manual the only fuse related to that area is the fuel pump. No fuse for the gauge/sender
Any help on this would be greatly appreciated  :smiley:
Offline shepgti
« Reply #5 on: 09 February 2009, 00:14 »
this seems to be common drove 3 days with it on the red until it ran out of fuel round the corner from my house, so i just trip it when i fill up.
Offline VR6-Joe
« Reply #6 on: 09 February 2009, 00:48 »
Mine's just always empty
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
« Reply #7 on: 09 February 2009, 08:54 »
Remove the wire from the sender and ground out if the gauge goes up then its the sender if not the gauge is knackered.
« Last Edit: 09 February 2009, 08:58 by wayned »
« Reply #8 on: 09 February 2009, 08:58 »
Mine was the same it is due to the weight on the end of the sender and how much fuel it has soaked up, I asked the dealer when mine was being serviced.
He told me it is a very common fault / problem.
Offline bondbill2k2
« Reply #9 on: 30 April 2009, 11:54 »
mm where can i get a sender from then?
Looked on gsf and couldnt find one, only found-
" FUEL PUMP SEND.TOP COVER           G3           54.0"
54.00 for a cover?  :huh:
