Author Topic: Help - fuel line eaten by rats  (Read 2900 times)
Offline Organisys
  • Old and Slow...
Re: Help - fuel line eaten by rats
« Reply #10 on: 13 January 2009, 22:10 »
When the car is fixed, run the rats over!
 :laugh:
Offline Ben Lessani
« Reply #11 on: 13 January 2009, 22:12 »
Thanks for that. I think mine must be a Digi looking at your photos. You reckon they can be joined then?
With a decent connection and a bit of good fortune, should be fine. Use strong clamps, not crappy jubilee clips ;)
« Reply #12 on: 14 January 2009, 09:38 »
No need to mess about trying to repair, just replace from another digi.  plenty of them around being broken and should last near enough forever since they're plastic!  If you do bridge it, be careful with using 'strong' clamps as the pipe will collapse if you go mental tight, the ends have a brass washer in to prevent this.
the feed line is discontinued but the return is still available:
191 201 355 D - 22.68+VAT
Offline Strev
« Reply #13 on: 15 January 2009, 22:06 »
Thanks mate. Bet its the feed then!
Offline Strev
Re: Anyone know a good scrapper
« Reply #14 on: 15 January 2009, 22:28 »
Anyone know a good scrapper then? One that might have a few MK2 GTIs around!!?
Offline Ben Lessani
« Reply #15 on: 15 January 2009, 22:33 »
Most people tend to keep their sources to themselves I've noticed.
Where are you based?
Offline nealey
« Reply #16 on: 16 January 2009, 00:11 »
I would get a length of fuel pipe from a motor factors and make them up yourself rather than relying on 2nd hand ones, ive seen a lot of threads recently about these pipes leaking and ive seen on quite a few scrappers badly perished pipes
