Author Topic: 8v wont start  (Read 11748 times)
Offline stew8vmk2golf
Re:8v wont start
« Reply #10 on: 25 June 2003, 19:00 »
yeah please mate
Offline richandhazel
Re:8v wont start
« Reply #11 on: 25 June 2003, 19:02 »
Also just found this:-
To ensure good starting and smooth running, the Digifant II system provides extra fuel to a cold engine. The coolant temperature sensor gives the control unit information on engine temperature. The control unit, in turn, makes an adjustment to injector opening time to provide the necessary richer mixture. For additional cold running driveability and fuel economy, the intake air preheat system warms the air entering the engine.
Coolant temperature sensor maybe?
Re:8v wont start
« Reply #12 on: 25 June 2003, 19:16 »
Re:8v wont start
« Reply #13 on: 25 June 2003, 19:28 »
couldnt display the graph for temp vs resistance
Re:8v wont start
« Reply #14 on: 25 June 2003, 19:30 »
are the fuel injectors supposed to have a constant live feed of is it supposed to fluctuate. the connector to the side of the fuel rail seems to have a constant live feed of the same voltage.
Re:8v wont start
« Reply #15 on: 25 June 2003, 19:38 »
Quote from the manual answers that:-
The injectors used by the Digifant II engine management system are electrically operated solenoid valves which are switched on and off (open and closed) by the Digifant II control unit
Re:8v wont start
« Reply #16 on: 25 June 2003, 19:42 »
Just sorting out the graph.........
Re:8v wont start
« Reply #17 on: 25 June 2003, 19:47 »
Hopefully the graph will show here:-
Re:8v wont start
« Reply #18 on: 25 June 2003, 19:55 »
thanks for that. the sensor is working correctly. the injectors seem to be recieving a constant voltage through the connectors. Any ideas why this is?
Re:8v wont start
« Reply #19 on: 25 June 2003, 19:58 »
2 secs..........I have something that may help you in fault-finding the problem..........
