Author Topic: Anyone had first hand experience of "Lucas oil stabiliser" ?  (Read 2945 times)
Offline Ben Lessani
Re: Anyone had first hand experience of "Lucas oil stabiliser" ?
« Reply #10 on: 13 January 2009, 10:40 »
True that! I was thinking of taking them out and cleaning them as per the guide on here and seeing if that helps.
What actually makes them noisy, insufficient oil flow?
Offline paultownsend
« Reply #11 on: 13 January 2009, 11:28 »
surely thicker oil will make the tappets worse? will be harder for the oil to get in and pump up?
mine are tit sometimes. tried all sorts, change oil (synta) every 3k and i still get 2 sticky ones :(
does anyone know the price of genuine items from vag?
VeeDubGTI16v
« Reply #12 on: 13 January 2009, 13:15 »
they were £6+vat each when i changed some 3 years ago, so probably more now! i went for the ecp ones which were much cheaper
Offline dirtydub
« Reply #13 on: 13 January 2009, 13:53 »
to be honest mate i wouldnt bother with treatments etc as far as the tappet noise goes. By all means take the tappets out and clean em up and see if it helps or better still get some new ones in there. I tried a few things to quieten mine thicker oil, oil treatments and an engine flush but nothing helped infact the flush just destroyed my already half knackered stem seals so i was bellowing blue smoke everywhere.
the treatments are great if you lose compression or fook ur engine as previously said but i think the
best way to go is new tappets and stem seals not too pricey just takes a little time
Rich
'86 golf gti 8v k-jet project up and running :)
Offline Ben Lessani
« Reply #14 on: 13 January 2009, 14:57 »
ECP
FEBI     n/a     311440030     HYDRAULIC CAM FOLLOWER PO/GO/JE/VE/PA/L.T./A80/A100
Hydro follower       £8.70
RUVILLE    n/a    311440031    HYDRAULIC CAM FOLLOWER PO/GO/JE/VE/PA/L.T./A80/A100
Hydro follower       £8.50
VeeDubGTI16v
« Reply #15 on: 13 January 2009, 15:18 »
just checked gsf and they are 4.90 there, they have got more expensive thats for sure!
Offline Ben Lessani
« Reply #16 on: 13 January 2009, 15:19 »
That's weird, I just checked GSF ...
14537           CAM FOLLOWER-HYDRAULIC           G2 8/85 >            7.25
VeeDubGTI16v
« Reply #17 on: 13 January 2009, 15:46 »
i didnt realise the old 8v had different followers
the list for these seems to show they are all the same! and they are nice and cheap
http://cgi.ebay.co.uk/VOLKSWAGEN-POLO-GOLF-PASSAT-HYDRAULIC-LIFTERS-x-8_W0QQitemZ380096631790QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item380096631790&_trksid=p3286.c0.m14&_trkparms=72%3A1301|66%3A2|65%3A12|39%3A1|240%3A1318
Offline Ben Lessani
« Reply #18 on: 13 January 2009, 16:04 »
Oooh, might invest in those, only a touch dearer than that oil!
But if I do that, it means it makes sense to do the valve stem seals too, which is a long ass process.
Offline dirtydub
« Reply #19 on: 13 January 2009, 16:42 »
yeah it can be a bit of a ball ache. Since ive had my head reconditioned no more irritating tapping on those cold mornings and doesnt use a drop of oil its a pain but its well worth it believe me will save you money in oil if nothing else.
i have some stem seals spare from my gsf head gasket kit if you would like them
Rich
