Author Topic: Cheap abf car!!  (Read 7322 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Cheap abf car!!
« Reply #30 on: 13 January 2009, 22:22 »
I can see another projects thread loomimg here! Entitled, 'Best standard MKIII showcar ever!'  :lipsrsealed:
Offline Jay
  • balding fat cvnt
Re: Cheap abf car!!
« Reply #31 on: 13 January 2009, 22:33 »
Laying in bits on DH's drive?  :grin:
Offline Diamond Hell
  • Opinions я Us
Re: Cheap abf car!!
« Reply #32 on: 13 January 2009, 22:44 »
Not outperform, I was just under the impression (from what I'd read) that the standard ABF was about 150 BHP, but the ABF block with KR head was more in the region of 160 BHP
Danny's is a standard ABF.
I'm tempted to stick my stock Toledo on the rollers up at Interpro to see what it's putting out at the moment.  Odds on it'll be delivering more than the 150bhp - this is a high-flowing motor - it WANTS to perform.
It doesn't need frantic remapping, as the management is designed to adapt and keep the engine running as well as possible under all conditions.  If you stick a free-flowing exhaust manifold on it then it'll up the fueling to accommodate the extra air through the motor.  You don't get that with K-jet, you just get the motor leaning out (see thread here) and struggling to provide reliable power.
The thread you're all thinking of already exists here.
Offline Ben Lessani
Re: Cheap abf car!!
« Reply #33 on: 13 January 2009, 23:22 »
Ok doke ;)
Out of interest, does the rear beam off a MK3 fit the MK2, I know you can whack the front end on to wide track it, but what do most folk do about the rear?
Offline Jay
  • balding fat cvnt
Re: Cheap abf car!!
« Reply #34 on: 13 January 2009, 23:29 »
Passat rear beam? or was that the syncro setup you needed a Passat rear beam for... ?
  • Opinions я Us
Re: Cheap abf car!!
« Reply #35 on: 13 January 2009, 23:54 »
Given that the Golf3 is just a Golf2 with lots of extra lard I should imagine you will be able to just bolt up the G3 beam.  It's not something I've ever done, but the Toledo (G2 chassis) that I have has a lot of G3 stuff on it, to take it to wide-track, which I think includes the rear G3 beam.  This would point to the beam being compatible with either.
The Passat has a different rear end set up - ostensibly the same as the Corrado.  Shame they didn't use it on the G3 - it might have actually moved the game on, instead of treading water.
Offline Bjork
Re: Cheap abf car!!
« Reply #36 on: 14 January 2009, 00:01 »
Could someone explain the difference between ABF and 9A or whatever it is? I don't know what you're all on about.  :cry:
Offline Horney
Re: Cheap abf car!!
« Reply #37 on: 14 January 2009, 00:07 »
ABF is fitted to MKIII Golfs and Toledos etc as DH has already pointed out and produces 150bhp according to VW. It runs on Digifant fuel injection int he MKIII Golf.
9A is fitted to late Corrado 16v's and late B3 Passat GT 16v's and produces 136bhp according to VW. It runs on KE-Jet mechanical fuel injection.
I don't know what differences there are between bottom ends but I believe the ABF is longer stroke than the  9A. Certianly the heads are almost exactly the same. The 9A however has a rubbish inlet cam and a 42mm inlet manifold whereas the ABF has a 50mm inlet manifold. Putting ABF (or KR) cams in a 9A and fitting the 50mm inlet manifold pretty much makes them equal on power and torque.
nick
Offline danny_p
Re: Cheap abf car!!
« Reply #38 on: 14 January 2009, 00:26 »
bore and stroke are the same.   the ABF is a tall block  the big differance been that the con rods are 159mm long as oposed to 144 mm long.
the 159mm rods give it a better stroke/rod ratio.    longer the rods reduce forces and thrust angels ect.
also toothed wheel in cranck and all that ect
all the VW's have gone bar 1.
Offline Bjork
Re: Cheap abf car!!
« Reply #39 on: 14 January 2009, 00:29 »
Cheers guys............I've learnt something new.    :smiley:
