Author Topic: where can i get a lightened flywheel??  (Read 3615 times)
Offline Gareth
« on: 12 January 2009, 20:14 »
hey all,
does any one know where can i get a lightened flywheel?? and whats the best weight to help turn my gti into a rev monster? cheers
Offline Jay
  • balding fat cvnt
Re: where can i get a lightened flywheel??
« Reply #1 on: 12 January 2009, 20:32 »
Buy a new one and have a local machine shop lighten it for you to the specified weight I guess. Not sure what weights are good though...
Offline Conker
« Reply #2 on: 12 January 2009, 22:52 »
Be wary of who you get to do this. I've seen pictures of a gearbox smashed asunder by flywheel shrapnel. Get a pro to do it.
Offline Diamond Hell
  • Opinions я Us
Offline 60fast
« Reply #4 on: 13 January 2009, 07:04 »
would be nice to have it balanced too if you building a motor have the the whole lot done  :wink:
oh try hotgolf didnt get mine off him but im sure he dose them and would sort you out
VeeDubGTI16v
« Reply #5 on: 13 January 2009, 10:31 »
when you go to get it balanced you need to take the crank and pressure plate as well
where are you? i have heard good things about basset down balancing  in swindon
« Last Edit: 13 January 2009, 10:38 by veedubgti16v »
Offline paultownsend
« Reply #6 on: 13 January 2009, 11:29 »
hotgolf did mine, but been hard to contact as of late  :sad:  top chap
Offline Gareth
« Reply #7 on: 13 January 2009, 18:13 »
ok cheers guys :) im on the isle of wight  :smiley: but the only problem living down here is every one thinks they can do every job and they all think the are a pro at it so i have to look off the island all the time to try and find some one who knows what they are talking about  :angry: im building a 2.1 liter 8v gti :) if any one has any ideas on what weight fly wheel would help turn it into a real rev monster? but it would also have to last more tahn a day with the power  :rolleyes: cheers
  • Opinions я Us
« Reply #8 on: 13 January 2009, 19:10 »
Are you using a cable-change gearbox, or rod change?
Makes a big difference.
I had my cable-change flywheel taken to 6kg from 9kg (IIRC) and it's still a fine drive.
There are *some* good people on the IOW.  Are you on IWEvoCars, Gareth?
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #9 on: 13 January 2009, 19:14 »
Personally, I would not lighten a flywheel unless I had the crank out as well, so that they could be lightened and balanced as a matched pair. Ideally, the clutch pressure plate could be added too, but these things get changed with the clutch, so you could be 'building in' problems later.
