Author Topic: Where can you order an R32 DSG intake from?  (Read 2990 times)
Offline richw911
Re: Where can you order an R32 DSG intake from?
« Reply #10 on: 13 January 2009, 20:50 »
DSG Intake  :smiley:
I did read it :smiley: but the pics are of the smoothed intake, not the R32 one.
The pipe pics at the bottom of the link  :wink: It will look stock when fitted - just has bigger intake pipe  :smiley:
Offline MrTurner
  • Facelift leon cupra
« Reply #11 on: 13 January 2009, 20:56 »
Cool ta  :smiley:
Is the filter the same size too then?
Offline richw911
« Reply #12 on: 13 January 2009, 20:58 »
Cool ta  :smiley:
You use the standard air box so yes
Offline MrTurner
« Reply #13 on: 13 January 2009, 21:01 »
Sorry, just didn't know if the R32 one was smoother but the same externally..  So could take a different filter.
Offline richw911
« Reply #14 on: 13 January 2009, 21:09 »
Ah i see- no AFAIK its the same. BTW You have to mod the standard air box to fit the DSG or buy the R32 box 70 pounds  :shocked:
Offline MrTurner
« Reply #15 on: 14 January 2009, 12:25 »
I think I'll just leave it, poss put a different panel filter in  :grin:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #16 on: 14 January 2009, 14:03 »
Just keep the standard air feed, but smooth your airbox & fit the panel filter, then. :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline ABOO
« Reply #17 on: 14 January 2009, 18:22 »
I've got my DSG feed kit in boot at minute. Might have a go at smoothing and fitting at weekend. In 2 minds whether just to smooth box for now and wait to fit dsg in a month or so when I upgrade all front bulbs.
Then again, will be taking advantage of R-tech prices before end of month, so might not even bother. Is there really any advantage over smoothed box and panel filter?.?.
2001 aum 1.8T
Offline the_stink
  • A3 140 TDI
« Reply #18 on: 14 January 2009, 21:11 »
smoothing the airbox basically lets more air get through as the small fins inside just get in the way its the same reson for the filter and DSG intake, alows alot more air to get through which then gives you a better throttle response  :smiley:
