Author Topic: Order of mods?  (Read 11027 times)
w0ffle
Order of mods?
« on: 12 January 2009, 11:18 »
p
« Last Edit: 18 November 2024, 19:41 by w0ffle »
Offline the_stink
  • A3 140 TDI
Re: Order of mods?
« Reply #1 on: 12 January 2009, 11:28 »
i would prob say and someone correct me if im wrong  :smiley:
sort out a few bits on the engine first to handle the first remap, so 007p, dsg +airbox, forge TIP
then when you get the stage 1 should handle and deliver the pwer better, then i guess it would be a case of the exhaust, FMIC or SMIC and then biger brakes if your lookign at a stage 2
well thats what i would do  :smiley:
Offline ben1.8T
Re: Order of mods?
« Reply #2 on: 12 January 2009, 11:32 »
You will also need 4 bar fuel pressure regulator. You will need to get a different turbo aswell I would say. With everything on your list I reckon you will only be looking at 240bhp-250bhp?
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline topher
  • Administrator
  • fully functioning
Re: Order of mods?
« Reply #3 on: 12 January 2009, 11:54 »
With a target of 300bhp?
First of all, forget using any of the KKK turbos.. they're just too small to make 300 on a 1.8
Turbo - GT28RS or similar with manifold to suit, possibly RS4 maf housing and a big cone filter (panel/dsg/smoothing won't flow enough) .. custom downpipe into a decat or milltek sports cat 3" min.
FMIC (the forge smic won't cut it) you can put a custom one together with all the piping for less than a monkey
Sachs clutch
Mapping - do it in one go, at the end.. because this is where the knowledge of the larger maf housing and matching fpr/injectors will really come in handy.
After that
Leon cupra R brakes will stop 300bhp
At the very least a good stiff spring setup with matching struts to handle the extra weight getting thrown around - coilovers pref. (not £150 ebay ones)
w0ffle
Re: Order of mods?
« Reply #4 on: 12 January 2009, 16:38 »
p
« Last Edit: 18 November 2024, 19:29 by w0ffle »
Offline JamieGTi
Re: Order of mods?
« Reply #5 on: 12 January 2009, 16:44 »
Jabbasport IHI turbo  :smiley:
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Order of mods?
« Reply #6 on: 12 January 2009, 18:11 »
like Topher said, its worth saving the remap to last as its pointless spending money twice as it could be used to go towards the needed turbo. Also upgrade to a 4 bar fuel pump as its ok having a 4 bar fpr but pointless if you cant supply the fuel to it.
Have a look at the APR stage 3 kit on awesomegti, it will give you abit more idea as to whats needed.
Jkctr
Re: Order of mods?
« Reply #7 on: 12 January 2009, 19:29 »
Car = 3k
Mods = 10k (including labour)
Total = £13k FWD car with 300bhp and is useless in anything but dry weather
or
http://pistonheads.co.uk/sales/840533.htm
Will piss over a 300bhp golf in every area (and any other 300bhp hatchback) and you will have change for a holiday!
Offline Rhyso
Re: Order of mods?
« Reply #8 on: 12 January 2009, 19:30 »
Car = 3k
or
ah yes you're one trick solution to everything
so tell me - why did you mod your CTR???
Offline dai-cymru
  • 1989 MK2 16V
Re: Order of mods?
« Reply #9 on: 12 January 2009, 19:32 »
order of mods
Rhyso 8359 posts
Rich   5934 posts
 :grin: :grin:
