Author Topic: Gearbox Oil Change  (Read 8875 times)
Offline VWaxilMK1cab
  • 1992 mk1 cabrio gti
Gearbox Oil Change
« on: 25 June 2003, 15:52 »
How much oil does the gearbox on a MK1 1.8 gti cab hold?
Where is the drain plug?
Offline richandhazel
Re:Gearbox Oil Change
« Reply #1 on: 25 June 2003, 18:12 »
Drain plug is right at the bottom of the diff and you will either require a big Allan key or the special tool.
Official capacities are 1.5 litres for 4 speed and 2 litres for 5 speed.
I did my 5 speed recently and didn't quite get 2 litres in so you should get away with just the 2.
Offline mr.brown
« Reply #2 on: 26 June 2003, 07:03 »
"richandhazel" - could I ask what type oil you used and was there a noticeable difference after?
« Reply #3 on: 26 June 2003, 09:56 »
Hi, I bought the 'Morris' 80/50 gear and differential oil from GSF.
I can't tell you whether it made any difference in this car as it was a non runner when I bought it. However I used to have a problem in my Audi coupe GT: After a long run down the motorway, when I came off and changed down it would 'stick' in gear and be difficult to change gear...........an oil change cured the problem.
Offline Justins145bhpMK1
« Reply #4 on: 26 June 2003, 11:11 »
You should use a straight 80w GL4 spec oil, I know this as I work for an Oil Company!!!
« Reply #5 on: 26 June 2003, 12:18 »
Sorry. misread what it said on the bottle. It is 'Morris' Lodexol 80W/90 gear and differential oil, API GL4.
« Reply #6 on: 26 June 2003, 12:34 »
Thatll do the job nicely, I can reccomend Castrol lubricants as being one of the best!
