Author Topic: Front camber????  (Read 768 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Front camber????
« on: 11 January 2009, 15:08 »
After fitting coilies on my valver, my front wheels look a bit knock-knee! How can I put a small amount of negative camber on the fronts? I don't want silly amounts=tyre wear!!!!
Offline Ben Lessani
Re: Front camber????
« Reply #1 on: 11 January 2009, 16:13 »
Depends on the coilovers I guess. Mine have a hole at the bottom and a slot at the top, so all you do is push in/pull out to suit your needs. If you're doing it by eye, then loosen the top bolt on the strut and push it as far into the car as poss, then tighten up. Or take it to any competent wheel alignment shop, they usually charge about £30 for camber.
Offline JC
  • Back in the North.
« Reply #2 on: 11 January 2009, 17:22 »
had mine set up on a Laser alignment kit - 2 x camber adjustments and 2 x toe adjustments = £55.  :cool: Sure there will be one near you somewhere :afro:
Offline sidecarphil
« Reply #3 on: 11 January 2009, 17:54 »
i did mine 2 weeks ago
but i now got some G60 brakes to fit , and i want to fit some suspensiona and stick some poly bushes in it while i'm there so got it all to do again  :cry: :cry:
but it handles well now  :wink:
