Author Topic: N249 bypass - Done  (Read 5139 times)
Offline Rhyso
Re: N249 bypass - Done
« Reply #10 on: 11 January 2009, 12:59 »
Quick question, great mod by the way.
I have removed my dv completly and blanked off the dv vac, so ...... am i basically getting the same mod here?
thanks,
urm im no expert but removing your DV completely doesn't sound good!!!
Offline vapor matt
« Reply #11 on: 11 January 2009, 13:07 »
thanks,
As said above, I wouldnt remove your dump valve mate, you will damage your turbo and engine if you over boost! the whole reason for a dump valve is to control over boost!
AGU. DSG intake. Eibach pro s coilovers. 312mm brakes. Miltech D-kat. KO3's. FMIC. R-Tech stage 2 remap. Big smile, bald tyres!
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #12 on: 11 January 2009, 14:22 »
As said dump valve isnt meant to be removed its there for a purpose ie to bleed boost back into the system if youve removed your dv? where have you/how have you sorted the pipes from the dv removal?
matt
2000 Mkiv GTi 1.8T AGU
kcolevol
« Reply #13 on: 11 January 2009, 18:37 »
No i been running it like this for a year just over, no probs (yet). I got the dump valve vac blocked off, the hard pipe boost hose is capped and a blanking plug in the intake pipe.  The boost pressure is still going through the exhaust as it would if there was a recirc on it anyway, the car idles fine and boosts still to my remapped 15 psi, never over boosted yet.
