Author Topic: camber settings?  (Read 3770 times)
Offline sharki786
  • GOT BOOST??
camber settings?
« on: 08 January 2009, 22:49 »
hi, sum1 told me on ere the reason why my car puls to the left is that the camber is out he said that he had sme prob as mine, trackin n balacing is bang on, so how is this done? can i do it myself? or where is the best place to go 2get this done? n wa am i lookin at (£££) im in birgimgham (5mins away from city centre)
thanks you ppls
 :wink:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Gambit
Re: camber settings?
« Reply #1 on: 08 January 2009, 22:57 »
what car is it?
if its a mk2 then just take it along to the alignment place and tell them you want it tracked straight ahead with 1.5degree negative camber on each front wheel
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 10 January 2009, 17:50 »
oh sorry DUH blonde moment. its a golf gti mk3 anniversary 8v (P Reg)
sorry
shaf
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 16 January 2009, 22:08 »
ne help??  :cry:
*****MK4 GTI T*****
Offline Mrpug
« Reply #4 on: 29 January 2009, 08:25 »
 1989 mk2 1.8 16v,, Is tracklng alignment,? is that the same as a 4 wheel alignment. Could a magnetic degree finder work? I put new front struts in.
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 29 January 2009, 10:40 »
Camber is adjusted in the same way as a Golf2.
You will need to take it somewhere like Protyre to get the front wheels properly aligned.
Personally I think 1.5 degrees negative camber would be a bit much for day to day use - it'll hunt on tramlines more than you might like and it you spend a lot of time on motorways it'll wear the insides of the tyres down too fast.  -0.5 degrees would probably be happier in day to day motoring.
Offline Mrpug
« Reply #6 on: 30 January 2009, 20:41 »
cool, I went to get a alignment, the mechanic, said that there is too much play rear wheel bearings and it won't align. Is this possible or was he scared  :shocked: to do a mk2 gti? I'm thinkin, since it's not a honda civic :sick: The poor lad.
« Reply #7 on: 31 January 2009, 10:23 »
well there aint anything you can do to align the rear (well, nothing an average spanner monkey at an alignment place can do anyway)
All you can do is get them checked, and make sure nothing is bent.
  • Opinions я Us
« Reply #8 on: 01 February 2009, 19:50 »
If you nip the hub up a touch tighter you might get the play out of it.
Make sure the bearings aren't binding though.
Offline Roverdose
  • So long and thanks for all the fish!
« Reply #9 on: 03 February 2009, 12:18 »
what car is it?
can you tell me if this aplies to corrado 1.8 16v aswell please?
