Author Topic: Common fault?  (Read 2903 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re:Common fault?
« Reply #10 on: 22 June 2004, 12:41 »
Took it to my man at the garage yesterday, as he was checking the engine bay he noticed that:
1) when you lifted the engine by the front mount there was about 3cm of movement, is this normal or should there be no movement what so ever?
2) the gear rod coming into the engine, there was alot of travel, the bush that it comes through seems to be worn! also after the bush where it is on a h type bracket it moved alot from side to side, Is this normal?
